1993 non turbo idi
1993 non turbo idi
question about the dual fuel tanks on my idi.
Are the front and back tanks the same or is 1 smaller then the other. because both of em leak, where is yet to be determined and i have a replacement fuel tank but i cannot tell if its the from or back?
Also the 4x4 shift lever is busted underneath the cab and i would like instructions on how to remove and replace it. thank you
There are a couple different sized fuel tanks, but they are TYPICALLY 19 gallons each. The sending units are PRONE to go bad and read inaccurately.
As for the 4wd shifter
https://www.ford-trucks.com/forums/1...er-repair.html
on
if you have a replacement fuel tank,you'll know where it goes very easily because the front (also refereed to as "mid ship") is long and skinny so to speak,compared to the rear which is wider and shaped much more like a square.
a quick peek below,and you'll soon realize which tank your replacement will be going.
rallynutdon
10-04-2016 04:31 PM
BombThreat
29
11-30-2014 07:29 AM
jgrzebin
11-29-2011 10:28 AM
jgrzebin
11-28-2011 10:34 AM
