Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Skipping noise in engine
Old Sep 14, 2012 | 02:24 PM
Jaguar2u's Avatar
Jaguar2u
Unhappy Skipping noise in engine
I just did tuneup on 2005 Ford Escape 3.0 V.6 four wheel drive. Changed the spark plughs and wireset. Did not change the ginition coil. When the engine run and heat up there is a skipping sound like the vehicle is loosing power.
Old Sep 14, 2012 | 02:29 PM
khadma's Avatar
khadma
Carpenter Local 745
This year of 3.0 Escapes have ECM problems.
Your computer maybe failing. We just replaced out daughters computer,
plugs and coil packs.
Have the computer checked before doing any more parts replacement.
Your dealer or VERY well qualified shop can do the check for your.
A few hundred on testing is better than thousands in repair if trying
to operate this truck as is.
Old Sep 14, 2012 | 08:02 PM
scott91370's Avatar
scott91370
These vehicles have a Coil on Plug system so if you changed the 'wires' you had to have changed the ignition coil(s).
My first guess would be wires plugged into the wrong coil. But that should cause you to feel a mis right away.
Next would be a bad gap on one of the plugs or a torn boot on a coil.
Are you getting a check engine light? If so have it read and they can tell you which cylinder(s) it is that is causing the issue.
Old Sep 15, 2012 | 08:23 PM
tonyford's Avatar
tonyford
There isn't an "ignition coil" in the Escape engine. Each spark plug has its own coil pack, so you would of had to change 6 coil packs to change the "ignition coil".
Thornido
Jun 24, 2023 11:56 PM
trike1946
Dec 10, 2017 12:42 AM
DItR
Apr 25, 2017 02:43 PM
apalo187
May 5, 2010 08:56 AM
rodhuffaker
1983 - 2012 Ranger & B-Series
Mar 1, 2004 05:03 PM
