changing the coil
Old Mar 1, 2004 | 12:50 PM
rodhuffaker's Avatar
rodhuffaker
changing the coil
the engine on my 1999 Ford Ranger was misfiring, not all the time, but usually at highway speed. Took it in and had it checked, and they say its the coil, and the spark plug wires. Can anyone tell me how to change the coil? I can do the plug wires, but have no idea how to change the coil. Can anyone help me out?
Old Mar 1, 2004 | 01:11 PM
PSKSAM2's Avatar
PSKSAM2
Welcome to FTE!
First thing that would help some people help you would be if you posted which engine you have in your truck.
I've replaced coils on distributor ignitions. They are usually easy to find by following the plug wire that doesn't go back to a spark plug. On a distributorless ignition, I'm not sure, but chances are someone on here has done it.
-Jim
Old Mar 1, 2004 | 01:18 PM
rodhuffaker
engine, coil
I know it's a V6, and it's distibutorless. I really don't know any more details though.
Old Mar 1, 2004 | 01:22 PM
Donald Rohret's Avatar
Donald Rohret
You need to tell these guru's what engine you have. If you can't see the coil then you probably have a distributorless ignition system. I'm no expert but my guess the coils are in the ignition coil pack. Trace the spark plug wires back to their origin and your there.
Old Mar 1, 2004 | 01:33 PM
rodhuffaker
ok, i've got a detailed description.
1999 Ford Ranger, 3.0L V6 EFI Flex
Hope that helps.
Is there a coil for each cylinder, in the coil pack, or just one coil, and is it difficult to remove the coil and replace it, etc.
Thanks in advance.
Old Mar 1, 2004 | 02:03 PM
Bob Ayers's Avatar
Bob Ayers
Hope that helps.
Thanks in advance.
There are actually 3 secondary coils, each coil fires 2 plugs in series at the same time. It should be easy to change out the
coil pack. There are 6 plug wires, and a connector that goes to
the PCM that fire the coils.
Old Mar 1, 2004 | 02:06 PM
rodhuffaker
coils
so, i cant replace the individual coils? Instead I just replace the whole pack? Thanks for the info, it was very helpful. How much does a coil or coilpack cost, generally?
Old Mar 1, 2004 | 03:14 PM
Bob Ayers's Avatar
Bob Ayers
Re: coils
Yes, you have to replace the entire coil pack. I just looked on Advance Auto Part's website, and it looks like the coil pack is about $72.
Old Mar 1, 2004 | 05:03 PM
rodhuffaker
thanks everyone. sounds like it should be a piece of cake.
Jose A.
Aerostar
Apr 11, 2014 12:35 PM
nojoke327
Apr 10, 2014 08:41 AM
tjs_79ford
Sep 20, 2009 11:30 AM
scram98400jm
Nov 10, 2005 05:03 PM
