Remove the second Tank and fuel pump
Old May 16, 2003 | 12:00 AM
randallc's Avatar
randallc
I am getting a new box for my truck and it only has a single fuel inlet. The box I have now has dual fuel inlets, but since the new one has only one I want to remove the second tank. I have been told that If the Computer in the truck dosent see the fuel pump, it will not even turn over. Is this true? or do I just have to make sure the tank switch is on the first tank to make the connection?
Thank you
Randall
Old May 16, 2003 | 12:33 PM
steve83's Avatar
steve83
The computer doesn't monitor the fuel pump - just the FP relay. If you keep the switch set to the remaining tank, you'll have no problem. In fact, you might cross each pair of wires so BOTH switch positions select the remaining tank.
Old May 16, 2003 | 12:42 PM
randallc's Avatar
randallc
Thought so... Thx
Old May 16, 2003 | 11:33 PM
Ford_Six's Avatar
Ford_Six
If the fuel door area of your old box is in decent shape, why not just cut it out and weld or rivet it into the new one? That way, you won't loose the range of the dual tanks.
Old May 17, 2003 | 12:53 AM
randallc's Avatar
randallc
I thought of that, but I rarely use both tanks. I am going to remove the front tank. This way I will be able to run my dual exhaust straight down each side instead of wraping it around to the one side and then back out to the other side.
Randall
LADNAR
15
Oct 24, 2012 04:02 PM
mantta
Jan 8, 2006 10:15 AM
boody101
May 2, 2004 04:59 PM
randallc
Alberta Chapter
Jun 28, 2003 10:55 PM
randallc
Apr 14, 2003 02:24 PM
