Sponsored by: Kumho
Cab Mounts
Old Apr 12, 2003 | 06:28 PM
randallc's Avatar
randallc
Cab Mounts
Hey all,
SO I climbed under the truck this afternoon to take a look at the cab mounts that I am going to replace... well they all look very easy to install except for one. The rear drivers side cab mount is hidden between the cab and one of the gas tanks.
Do I have to remoce the gas tank? or is there another solution to this?
If I have to remove the gas tank, what should I look out for while removing it?
Thx
Randall
Old Apr 13, 2003 | 09:50 PM
bugsy's Avatar
bugsy
Cab Mounts
Its fairly easy, look for the gas tank strap bolt on the frame. I am talking about the strap that bolts to the same crossmember that you are working on. Anyway just remove that bolt an let the tank hang from the rear, It wont hurt anything and You'll have some room to play around, without removing the tank. I just did a body lift on my 93' and I had all the room I needed.
Hey while you are down there rplacing those bushings throw in a three inch body lift. looks great.
good luck, mike.
Old Apr 13, 2003 | 10:11 PM
randallc's Avatar
randallc
Cab Mounts
Thx for the tip.
I would put in a body lift if I had a 4x4, but this truck is for haulin my clasic cars etc... I don't think it would look that good with a a lift in it and I dont think I know of anyone that has done a body lift on a 4x2.
Thx
Randall
Old Apr 14, 2003 | 12:24 AM
bugsy's Avatar
bugsy
Cab Mounts
good luck either way.
Old Apr 14, 2003 | 07:37 AM
swirk's Avatar
swirk
Cab Mounts
You do have to drop the front tank. I would suggest running it almost empty before you drop it out of there. You don't have to unplug the pump, just let it down on the front end. Just enough so that you can get to that bolt.
Old Apr 14, 2003 | 11:34 AM
randallc's Avatar
randallc
Cab Mounts
Thx guys... I will remove the front tank braket and let it hang from the rear.
Old Apr 14, 2003 | 12:23 PM
tsheriff's Avatar
tsheriff
Cab Mounts
Where did you get the body mounts and how much did they cost? Im going to do a body lift soon so i will change the mounts while im at it.
Old Apr 14, 2003 | 02:24 PM
randallc's Avatar
randallc
Cab Mounts
The ones I purchased are the "Energy Suspension" Polyurethane body mounts. You can check em out HERE . I purchased mine from a local company in Vancouver Canada, called Mopac. I don't know where you can get em if you are in the US, but if you are in Canada, go to Mopac. I paid about 85.00 CDN.
rickb
Jan 28, 2024 07:18 PM
topmoo
165
Jun 6, 2018 09:36 PM
ThinkItBuildIt
Jul 5, 2015 11:00 AM
1950FordF1
Jun 14, 2015 09:27 PM
cjben
Sep 9, 2008 08:22 AM
