No fan
Old Sep 13, 2012 | 08:40 PM
ReBilld's Avatar
ReBilld
No fan
I had the fan and shroud off the 250 this evening to change the power steering pump, and I decided to leave them both off and see how it does.
Old Sep 13, 2012 | 08:47 PM
quesey's Avatar
quesey
did the 97 the same way till i get the motor lined out.
just can't use ac much without it sitting still lol
Old Sep 13, 2012 | 08:50 PM
ReBilld's Avatar
ReBilld
LOL, my ac condenser has a hole in it and the ac doesn't work anyway
Old Sep 13, 2012 | 09:00 PM
stainlessstroker95's Avatar
stainlessstroker95
I think william has been doing that for a while now too bill. And i dont think he has had any trouble with it except the ac thing.
Old Sep 13, 2012 | 09:16 PM
BlueMule's Avatar
BlueMule
I took mine off 5 years ago to replace a water pump and still haven't put it back on.
Old Sep 13, 2012 | 10:35 PM
fordman67's Avatar
fordman67
Mine took flight into the rad...so i did electric fans...except my alt is not up to it.so i have them unhooked...no problems here...dont know what to do...so i do nothing!
Old Sep 14, 2012 | 08:36 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Originally Posted by BlueMule
I took mine off 5 or maybe 6 years ago to replace a water pump and still haven't put it back on.
And with your electric fans has been enough to control the engine temperature and for the A/C?.
Old Sep 14, 2012 | 09:13 PM
ReBilld's Avatar
ReBilld
Drove to work today, and went to town after work. Sat in some traffic, and drove through town at slow speeds........did fine.
Old Sep 14, 2012 | 09:38 PM
fordman67's Avatar
fordman67
Its the most amazing thing.i never would have thought without trying it myself.these things must really use the thermostat to get any heat.
Old Sep 15, 2012 | 07:56 AM
rodneywar's Avatar
rodneywar
yea the cooling system on the trucks when working properly is over kill for the trucks
Old Sep 15, 2012 | 09:43 AM
Talyn's Avatar
Talyn
If you want no fan and and AC still, just hook up a fan behind the area where the AC condenser is. It will pull enough air if you got a good enough fan there.
They make some really high powered Computer fans that you could just attach there and they are 12 volt with not a high draw. I'd put it on a switch though and a relay.
No issues here running no fan.
My AC system isn't charged, so I dont' get that luxury.
I'ma run down to the college here soon and see if they will do it in the automotive bay.
Old Sep 15, 2012 | 11:10 AM
BlueMule's Avatar
BlueMule
That was the electric ones I removed to replace the pump Jose, I haven't had any fans since then.
The electric Windstar fans did just fine with the Arizona summers. One was set to run whenever the AC was on and the other was controlled by an adjustable thermostat that was set for 205*
Old Sep 15, 2012 | 03:44 PM
Talyn's Avatar
Talyn
Rodneys signature isn't up to date. thats the issue here. =)
Old Sep 17, 2012 | 09:43 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Thank Rod. Here in my country the summers are worst and the winters are not to bad, so I dont know about use or not use the fan
Yeap that confussed to me.
MikeRizz
6.4L Power Stroke Diesel
Jul 10, 2014 08:47 PM
bass-n-fire
13
Aug 3, 2011 08:24 PM
Grodyman
May 11, 2010 06:36 AM
texasjack
Jul 20, 2009 02:49 PM
cyberfire
Feb 7, 2004 02:51 PM
