i have a 96 f350 4x4 cc 7.3 with a propane injection system i have a 50 gallon tank can i use the regular forklift style tanks due to this 50 gallon tank jus eats up to much of my bed or a company that makes them custom id like to put t in my spare tire well
thiers a night and day diffrence when the propane is being used to when i turn it off i dont wanna remove it as power is nice addition tio this dog im jus lookin to downsize my tank for space reasons
thiers a night and day diffrence when the propane is being used to when i turn it off i dont wanna remove it as power is nice addition tio this dog im jus lookin to downsize my tank for space reapsons
you can only use a forklift cyl if tour system is a liquid system , if it is a vapor system them a forklift cyl will not work.
Most propane injection systems use liquid propane. Once injection into the intake it then turns in a vapor. The design of the tanks are different, IIRC the vapor propane is drawn out of the top of the tank and the liquid type is drawn out of the bottom of the tank.
Look at the tag that should be below the valve on your existing tank, it should say liquid. Make sure to mount your forklift tank securely and you will need to add the female forklift connector to you existing hose so you have a quick disconnect to change out tanks as needed. Some of the ag systems from years ago had a vaporiser that tied into the water jacket and used engine heat to vaporise the fuel. There are some newer systems that directly use liquid. I am learning alot about Diesels but I do know propane.
If I can help let me know.
