so a buddy of mine informed me that his 5.0 is shot. and heres the question, he has a 1989 ford mustang h.o. 5.0 block in his garage stamped with XXX . it was a roller block, but will it work in a speed density truck? putting in a non roller cam and such. im not sure if the block is the exact same and will work for a f150
Just use your cam and check the lifters if they are rollers or flat tapered, should be fine, otherwise, firing order is different from the 5.0 to 5.0 HO. Just change for that.
What you got here is an opportunity to install a HUGH upgrade in that truck. Believe it or not the blocks for those two motors are the same.. all 5.0 blocks are the same really, but the cams are nothing alike and that's a good thing because the stock '89 truck cam is brutally bad. So my suggestion is to install the HO shortblock as it is with 1 modification, go get an adjustable timing set and advance the cam 4 degrees, then put the truck intake and accessory brackets on it and stuff it in there. The only change you need to make electrically is to route the plug wires for the HO firing order, the motor will run normally but will make quite a bit more power than the old corked up mess.
thats awesome! he also has an e303 cam for that same motor although not installed, if he put that in the motor and installed it would it work? or is it best to just keep it all stock h.o.
There was a serious issue involved with using a NON-H.O. camshaft in an engine originally built as the H.O. version.
Non-H.O. engines (non-roller-cam engines) used CAST IRON driven gears on the distributor shaft. Use of a roller-cam (H.O.), to avoid "eating" the cast iron distributor gear, required it's replacement with a STEEL gear.
ive been looking for a roller cam thats SD friendly, and i think ive found one, comp cams 35-320-8. does anyone know if this cam really is SD friendly?
No it's not really SD friendly and besides that you pretty much get the same thing but in a more SD friendly package by adding 1.7 rockers to the HO cam.
