1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Best spark plug for 08 6.8L V-10
Old 09-13-2012, 01:22 PM
WestxSRT10's Avatar
WestxSRT10
WestxSRT10 is offline
I have searched and still can't come up with the best/safest spark plug for my 2008 F-250 6.8L V-10.
There are 6 differiant plug choices at my local auto parts dealer.
I have 42,000 mi on my truck and it runs great, should I change the plugs?
Old 09-13-2012, 01:41 PM
mudfuel06's Avatar
mudfuel06
mudfuel06 is offline
Motorcraft is the best choice. Try Rockauto for the best price. I woudl change them about every 60k.
Old 09-13-2012, 04:46 PM
dualwheels66's Avatar
dualwheels66
dualwheels66 is offline
Motorcraft plugs are the best, just MAKE SURE they are the one piece plugs and the dealership is not trying to get rid of the two piece plugs at your expense. I change mine every 50K.
Old 09-13-2012, 06:24 PM
dkf's Avatar
dkf
dkf is offline
Depends what design you have. I am almost 100% positive the breakage issue was never fixed with the Motorcraft or Autolite plugs for the old design 3V plug, they are still 2 pc. For those engines I would go with a 1 pc plug like Champion or Brisk.(Rock Auto has good prices on the champion) You can pull one of the COPs and see what the color the COP boot is. Trucks with the old design are supposed to have black COP boots and the new design is supposed to have brown COP boots. For the most recent design mid 08'up plug I would go with the Motorcraft. You could probably stretch the plugs out to 50k miles without problem but you just do not not know what issues you could run into if you have the old design plugs.
New design 1 pc top. Old design 2pc bottom. Not interchangable.
Old 09-13-2012, 07:28 PM
Gage2502's Avatar
Gage2502
Gage2502 is offline
YA I dont think that Motorcraft changed the design of the two piece plugs.
~Gage~
Old 09-13-2012, 09:08 PM
WestxSRT10's Avatar
WestxSRT10
I think I'll pull a plug out tomorrow to see what type plug I have.
I checked and have the brown boot, I'm attempting to remove the plug per TSB.
Thanks guys
Old 09-13-2012, 09:57 PM
dkf's Avatar
dkf
dkf is offline
Since you have the brown boot you should have the new design that does not snap off. Take it slow removing the plug and do it on a cool engine and you should be fine. Do not be surprised if the plug squeals a little on the way out. With the new design plugs you could most likely leave them in a while yet.
Old 09-13-2012, 10:29 PM
WestxSRT10's Avatar
WestxSRT10
I removed the plug before I read your last post.
YOU ARE 100% CORRECT...IT DID SQUEAL!... gave me that sick feeling but it came out without an issue. The plug looks good so I may just leave them in till 60K.
(used Aero Kroil as a lube, took 15-20 min total)
Thanks for the help.
X-70STANG-F150
Modular V10 (6.8l)
05-28-2009 02:37 PM
calbery
Modular V10 (6.8l)
10-12-2007 10:09 PM
hdbloodtrail
Modular V10 (6.8l)
21
09-04-2007 01:05 PM
FULLQUIVER
Modular V10 (6.8l)
07-21-2007 02:28 PM
andrewzx92000
Modular V10 (6.8l)
02-26-2007 07:39 PM
Quick Reply: Best spark plug for 08 6.8L V-10
