Sponsored by: Real Truck
Front suspension fitting
Old Sep 9, 2012 | 12:52 PM
sean1997's Avatar
sean1997
2002 F350 4x4, what is this fitting for (see red arrow)? It is located on the top, front of the steering knuckle and has a rubber cover, which I've removed for the picture.
Old Sep 9, 2012 | 01:14 PM
2000silverbullet's Avatar
2000silverbullet
Is that the fitting for the ESOF vacuum line (to engage/disengage the hubs)?
Do your hubs work when you flip the switch in the cab (if equipped)? If not, that's probably why. It's common when the hubs stop working to just cap off the lines and work the hubs manually, switching between auto/lock when needed.
Old Sep 9, 2012 | 01:39 PM
sean1997's Avatar
sean1997
No, my truck is an XL so it doesn't have power anything. There isn't any switch in the cab, so I have to lock the hubs manually.
Old Sep 9, 2012 | 01:51 PM
2000silverbullet
Hmph... It looks vacuum to me, unless they use the same components whether you have esof or not, and just cap it on the ones that don't.
I don't know, sorry.
Old Sep 9, 2012 | 01:53 PM
sean1997's Avatar
sean1997
Yes, that's possible. It doesn't look like its ever been used.
Old Sep 10, 2012 | 02:36 PM
bbender85's Avatar
bbender85
its the vacuum fitting for the ESOF system. if you have the transfer case shift lever on the floor you don't have / have no need for the vacuum system, which is why it's capped off.
Old Sep 11, 2012 | 11:03 AM
SuperDutyScaler's Avatar
SuperDutyScaler
its the esof vacuum line fitting, it doesnt matter if you have it or not ALL Fords have the nipple in the knuckle. If it were me id remove the nipple and install a stainless 1/4" plug. My dads 2000 rubber cap rotted off and for years water/salt/ etc got into the nipple and rusted up everything really good.
Old Sep 12, 2012 | 07:29 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Um, apparantly not "ALL Fords."
My Ford (2000 4x4) didn't come with any such nipple on the knuckle.
I just went out and triple checked to make sure, and had an Excursion with ESOF to compare it to side by side, so I would know exactly where to look.
No nipple. MSOF. (Manual Shift on Floor).
Old Sep 13, 2012 | 03:12 AM
BigAlsPSD's Avatar
BigAlsPSD
Unique, my 2000 has them capped off, and it is manual transfer case.
Old Sep 14, 2012 | 12:02 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Hmmm. that is kind of surprising that there would be a difference. I would expect them to be the same?
Maybe the 550 front axles are different? I didn't think they were, other than the wheel hubs and the brake rotors. Maybe the absence of the fitting is another difference?
Back in 2000, ESOF was not even an option on the F-550 (nor F-450 chassis cab). ALL F-550's were manual transfer case only... even the Lariats (mine is a Lariat).
Sous
32
Oct 16, 2015 12:57 AM
Bluegrass F250
Jul 6, 2011 05:36 PM
pjnadon
Jan 17, 2011 09:33 PM
Ace!
Dec 30, 2007 02:11 PM
mike330
Modular V10 (6.8l)
19
Jun 5, 2007 11:57 PM
