Sponsored by: Real Truck
new guy here PLEASE HELP
Old Sep 13, 2012 | 06:02 AM
boom24's Avatar
boom24
Exclamation new guy here PLEASE HELP
I WORK AS A FLEET MECHANIC FOR A SMAL CONSTRUCTION COMPANY..IAM HAVEING ISSUES WITH A TRUCK THAT I NEED SOME HELP WITH...ILL START WITH ITS A 2004 F350 V10 WITH DRW..THE TRUCK HAD A NASTY DRIVE LINE VIBRATION FOR THE PAST FEW MONTHS..MY BOSS DIDNT WANA FIX IT 2 WEEKS AGO THE TRANS BLEW UP ..LIKE SOMEONE STUCK A STICK OF TNT IN IT..HEAR IS THE PROBLEM GOT A USED TRANS PUT IT IN ..NEW RANGE SWITCH.BOTH SPEED SENSORS NEW FLUIDS AND FILTERS AND INSTALLED A AFTERMAFKET TRANS COOLER AND GOT RID OF THE STOCK ONE..THE TRUCK DIDNT SHIFT INTO OVERDRIVE. AND WAS SLIPPING VERY BADLY..SO GOT A REMANED ONE AND THE SAME ISSUES ARE HEAR AGAIN ..OVER DRIVE LIGHT FLASHING BUT NO CODES..ANY IDEA WOULD GRATLEY HELP AND I DONT HAVE A GOOD ENOUGH SCANNER TO CHECK ANYTHING IN THE TRANS EXCEPT CODES ...IF ANYONE HAS ANY SUGGESTIONS OR IDEAS PLEASE CALL OR EMAIL ME ASAP ..THANK ALL OF YOU SO MUCH JUST FOR READING THIS
MY CELL IS 7812431301
EMAIL IS DAVEF249@GMAIL.COM
THANKS DAVE K
Old Sep 13, 2012 | 06:03 AM
boom24's Avatar
boom24
ALSO TRANS IS 4R100 AND IT IS A 4X4
Old Sep 13, 2012 | 06:08 AM
redford's Avatar
redford
FTE Leadership Emeritus
Hello boom24 and welcome to FTE.
If the OD light is flashing, then you have an error code. You need to get that code and post it here.
As for the new transmission, you said it has the "same issues". The same as what? The original or the 2nd transmission? The original "blew up".
As for the original vibration, if it is still present it sounds like it wasn't the transmission causing the issue.
Old Sep 13, 2012 | 07:19 AM
boom24's Avatar
boom24
scanned it no codes present or pending...same issues as second trans not shifting rite .seems to shift to soon and slipping very badly and not going into over drive..i cant get it past 30 mph..the driveline vibration i had was 45mph +++ so i cant even test that issue yet eather ..sucks cause my boss wants to send it to a friends shop..i feel like iam getting **** on..iam lost ..the guy told my boss that the stock cooler has check valves in it..never herd of anything like this before..and he told him that the range sensor could cause this.. i put the truck in nutrel and lined the switch up and ive installed many aftermarket trans coo;ers befor and never had a issue..to test what the guy said about the cooler i blew air into the cooler and flowed both ways ..i do know the trans fittings that go into the trans have check *****...please help..
thanks again
dave k
7812431301
davef249@gmail.com
Old Sep 13, 2012 | 07:53 AM
blk250's Avatar
blk250
You may double check all your electrical connections. When I replaced the transmission in my 04 Silverado I had, I bent one of the pins on one connector and it caused it to not shift at all. The slipping issue you are having sounds weird, but I would at least start with that. Also the trans isn't over or underfilled is it?
Carnes99
Dec 21, 2019 06:56 AM
Kenny Hernandez
Jul 7, 2019 02:24 PM
UNTAMND
Apr 10, 2013 06:09 AM
crawlinrs
Apr 17, 2006 06:37 PM
