Sponsored by: Real Truck
Keyless Remote Problem
Old Sep 12, 2012 | 01:59 PM
300sflyer's Avatar
300sflyer
The keyless remotes for my 08 F350 are not operating as they should. For some reason, the truck will only accept the programming for one remote. I have followed the correct procedure to program them [key on/off 8 times staying on, then activate both remotes, then key off] several times with no success. I have tried several different remotes and new batteries, thinking that was the problem, but still no luck. No matter what I do, I can only get the truck to remember one remote.
Anyone have any suggestions? Thanks!
Old Sep 19, 2012 | 08:15 AM
300sflyer's Avatar
300sflyer
Anyone have any ideas where to start looking on this issue?
Old Sep 19, 2012 | 08:41 AM
sammy77's Avatar
sammy77
Are the door locks cycling when you're programming? For both remotes?
Old Sep 19, 2012 | 09:10 AM
300sflyer's Avatar
300sflyer
Yes, they are cycling both at the start and finish of the programming and for both remotes.
Old Sep 19, 2012 | 11:24 AM
sammy77's Avatar
sammy77
You are programming 2 identical remotes? I had a similar issue a few years back on a truck I was working on. I had an issues where it would not go into programming mode. I ended up disconnecting the batteries, and unplugging the module waited a bit, reconnected batteries, then module. Someone suggested I try this first and it worked!
Old Sep 19, 2012 | 11:36 AM
300sflyer's Avatar
300sflyer
The remotes are identical. I did try disconnecting the battery, with no luck. Which module are you referring to and where is it located? Thanks.
Old Sep 19, 2012 | 12:34 PM
sammy77's Avatar
sammy77
I believe it's still called the vehicle security module?
Old Sep 20, 2012 | 07:12 AM
300sflyer's Avatar
300sflyer
OK... Thanks. I'll see if I can locate it in the truck.
Old Sep 20, 2012 | 08:19 AM
sammy77's Avatar
sammy77
The truck I had an issue with was an '04 and I believe it was located behind the radio area. Maybe start in that area? Hopefully someone will chime in with some help...
Old Sep 20, 2012 | 07:08 PM
Bigalsr's Avatar
Bigalsr
I'm having the same problem with my 99 F250. The locks cycle but the remotes won't program to work. I have tried this 25 times but never unhooked the battery to try that. I'll see it this works.
Old Oct 27, 2012 | 11:55 AM
300sflyer's Avatar
300sflyer
Still have this issue with my remotes guys. Hope someone has a solution. I have not been able to locate the security module.
Old Oct 27, 2012 | 01:42 PM
Bigalsr's Avatar
Bigalsr
Same here. I haven't tried anything as of late, was waiting for some answers.
Old Oct 27, 2012 | 02:41 PM
Yahiko's Avatar
Yahiko
I know that they lock the number of keys in the E-PATS system.
Could there be some thing like that for the remotes?
If that is the case your going to need someone that has access
to a programer like the IDS system at the dealership.
I had a 3rd fob tjat would not program and it had
something to do with having the door open or some odd thing
like that. As I think about it Maybe it was door closed and locked
before I could get it to go into programming mode.
Sean
BoulderF350
May 31, 2018 02:11 PM
rc.chris
Jul 31, 2012 03:36 PM
FordMan35
Nov 29, 2009 02:02 PM
br0nc0
Electrical Systems/Wiring
Jul 29, 2005 09:36 PM
Steve
Sep 1, 1999 04:33 PM
