PS pump is NOISY!!!
Old Sep 11, 2012 | 10:26 PM
SkySkiJason's Avatar
SkySkiJason
PS pump is NOISY!!!
I replaced the PS pump with one from autozone ~50k miles ago when I rebuilt the engine. The stocker had 308k miles on it and had a small leak for a loooooong time, but never really made any noise. This pump whines and moans like my ex-wife . It is really loud and is most noticeable at low rpms when turning (like sharp turns coming down the mountain) and also when pushing hard on the brake sitting still.
I have MOBIL 1 ATF in the system. Is that the problem?
Fixin' to replace the water pump (see my other thread) and will prolly just swap out the PS pump while my hands are dirty and the tools are out. Should I use non-synthetic ATF?
Old Sep 11, 2012 | 10:38 PM
carltonwebb's Avatar
carltonwebb
Jason, when u bled the air out of it. Did u do it with the wheels on the ground or off the ground? It sounds stupid, but was proven that it can & will make a difference not long ago.
Bled it with the wheels off the ground and issues went away.
Old Sep 11, 2012 | 11:04 PM
CSIPSD's Avatar
CSIPSD
I HATE Lucas oil products...
But one I do SWEAR by is the powersteering leak fix...
I run two bottles in each PS pump and have no whine, or issues what so ever.
Try it before you swap pumps...
Old Sep 12, 2012 | 07:05 AM
SkySkiJason
System was bled with wheels off the ground. Maybe I'll jack it up and run the wheels lock-to-lock a couple times for good measure. It wasn't noisy at first, but doesn't seem to have changed much since it started... I really thought it was low on fluid when the noise started - but it hasn't used a drop in 50k miles.
I'll try the lucas. Can't hurt!
Thanks guys.
Old Sep 12, 2012 | 10:35 AM
TinyWonder's Avatar
TinyWonder
What about trying a different synthetic oil to see if that makes a difference. Kind of like using the Lucas product, it's going to be cheaper than replacing the entire pump.
Old Sep 12, 2012 | 10:55 AM
empiretc's Avatar
empiretc
see this thread:
https://www.ford-trucks.com/forums/1...ing-whine.html
to this day, not a peep!
Old Sep 12, 2012 | 11:44 AM
timmyboy76's Avatar
timmyboy76
Ya, me too, but it DID fix my hard shifting when fluid was warm/hot. Added a bottle to the zf6, and within a block, i could tell the difference...(mercon V along with it).
Old Sep 12, 2012 | 09:11 PM
SkySkiJason
The pump is free - lifetime warranty. My time on the other hand IS NOT...
Originally Posted by empiretc
see this thread:
I gotta go to the parts store in the AM, I'll give one of the additives a try!
Old Sep 12, 2012 | 09:16 PM
Kdr358's Avatar
Kdr358
+ 1 on the lucas power steering fix. It quieted mine down untill I can replace mine and flush the system
Old Sep 12, 2012 | 09:17 PM
MuddyHill's Avatar
MuddyHill
I'm a newbie so please redirect if necessary - - I have a 'pssst' type noise when I turn the steering wheel left of right. - should i be concerned?
npccpartsman
1997 - 2003 F150
Feb 19, 2019 01:21 PM
jb10725
1983 - 2012 Ranger & B-Series
Dec 16, 2012 04:56 PM
weekendwarriorfsw32
Sep 28, 2009 03:45 PM
ADSf100
1978 - 1996 Big Bronco
May 13, 2005 09:46 AM
Vampiro
Jun 21, 2002 12:25 AM
