Dash cluster light problems???
Old May 15, 2003 | 08:20 PM
clean79150's Avatar
clean79150
I have a 1979 F-150, and the lights in the dash cluster, and the gauges themselves sometimes just don't work, and then other times they do. This happens about once a week or so, I'll look at my gauges, and the temp and oil are at the far left, and then a few miles down the road they go back into the normal range. I know I should upgrade to mechanical gauges, but that would be ignoring the problem.
I can't figure out what is wrong. A friend told me that there is some sort of circuit board that may need replaced. Is there such a monster, and what would it be called, and where could I get one???
I tried the archives, and couldn't find any other problems that were like mine.
Old May 15, 2003 | 08:25 PM
steve83's Avatar
steve83
Mi1lion will probably have the exact answer, but check your dash grounds.
Old May 15, 2003 | 08:39 PM
Mil1ion's Avatar
Mil1ion
A few things to check.
First remove the instrument cluster:
1) inspect for crack & clean the *printed circuit* on the back of the cluster.
This is what distributes the current to where it is supposed to go.
2) Inspect & test the Instrument clustser voltage regulator for current output & current pulse speed.
3) You mention lighting too.
This is all part of the same system.
This printed circuit can be replaced (e-mail me).
Old May 20, 2003 | 07:55 PM
clean79150's Avatar
clean79150
Thanks Mil1ion, I never knew there was a monster. I'll get it ripped apart next time I have a few days off of work.
Old May 20, 2003 | 11:02 PM
Mil1ion's Avatar
Mil1ion
No doubt you have seen the front !
Well.....Here's the back
kegger66
Sep 1, 2016 02:02 PM
tazmans
1983 - 2012 Ranger & B-Series
Feb 28, 2016 07:41 PM
SlikWillie
Oct 2, 2015 07:35 PM
countryboyco99
Sep 30, 2015 10:22 AM
callman
1997 - 2003 F150
Jun 2, 2008 04:01 PM
