Engine Idle Problems
Old Sep 11, 2012 | 05:31 PM
HollywoodHeiss's Avatar
HollywoodHeiss
I recently bought a 89' F-150 V8 fuel injected and still had all factory parts in it. Same engine, same tran, the whole thing. For having all the original parts installed it runs great. The only problem i am having is whenever i sit at the stop sign i noticed the engine wants to die. Either it is not getting enough air or the fuel is not sufficient enough. I changed the fuel filter thinking it was getting clogged in there, but it still does it. Took the idle air control valve off and the throttle body off and cleaned the gunk out, but still does it. It acts like it is starving from one or the other and is fighting to stay at idle. When i turn the a/c on it will do it less. I was wondering if anybody else might have had or is having the same problem and might be able to help me out. I never worked on a Ford before only Chevy so i am new to this engine and plus its fuel injected, only worked on carburetor engines. Any help would be awesome. Thanks.
Old Sep 12, 2012 | 11:21 PM
rla2005's Avatar
rla2005
Original parts as in plugs/wires/cap/rotor and filters? If so, start there.
Old Sep 13, 2012 | 01:40 AM
HollywoodHeiss
yea original plugs/wires/cap/rotor etc, i changed fuel and air filter. checked the voltages and they check good on the wires. fuel injectors had a little build up but i cleaned those off. no miss fires or arcs. i think its either air or fuel being starved or a combo of both. does it sound like I'm on the right track or no?
Old Sep 13, 2012 | 08:54 AM
rla2005's Avatar
rla2005
23 year old high-voltage components are not going to perform like fresh/new parts. You are fooling yourself if you think otherwise.
Old Sep 16, 2012 | 04:50 PM
HollywoodHeiss
yea i figured that but for age the truck is in the wiring is better than i expected but found out it was the timing was bad. the only reason why it was working was that the computer was trying to compensate for the offset of the distributor
Old Sep 16, 2012 | 09:08 PM
rla2005's Avatar
rla2005
Glad to hear you think you have it fixed.
bozo4ford
1983 - 2012 Ranger & B-Series
Jul 22, 2012 01:55 PM
oakland25164
May 4, 2010 11:16 AM
wyatt earp45
Feb 19, 2010 07:38 AM
austinpower
3.8 & 4.2L V6
52
Jun 1, 2004 10:29 AM
jethrp007
Dec 12, 2002 12:01 AM
