limited slip??
Old Sep 15, 2012 | 03:16 PM
bassman94's Avatar
bassman94
limited slip??
so i have a 1995 f150 351. im thinkin its got 3.55 gears? and no limited slip? i was wondering if you guys had any thoughts involving my figures to be right?
Old Sep 15, 2012 | 03:23 PM
Conanski's Avatar
Conanski
Go out to your truck, open the drivers door and read the axle code off the calibration decal on the door pillar, then compare it to the list below and you'll know what you got and won't have to guess.
Ford Axle Code Chart .: Articles
Old Sep 15, 2012 | 03:28 PM
bassman94's Avatar
bassman94
its sayin "18" which states a 3.08 no LSD but for a 1991. i have a 95, any other charts closer to my year or do you think its the same regardless of year
Old Sep 15, 2012 | 03:39 PM
Conanski's Avatar
Conanski
You can ignore the year column in that chart it's the same for all years.
Old Sep 15, 2012 | 03:42 PM
phoneman91's Avatar
phoneman91
It is the same-3.08 open differential.
If limited slip is important and you want to verify if further-jack up the rear axle and place the transmission in neutral and turn one of rear wheels in one direction-if the opposite rear wheel turns in the same direction- the differential has a limited slip. If the opposite wheel turns in the opposite direction-it is open.
Old Sep 15, 2012 | 06:09 PM
bassman94's Avatar
bassman94
alrighty, and what do you guys think about changin to a limited slip if i get a gear change, lower after i get a lift is what im lookin for. to diffiecult to be worth it?
Old Sep 15, 2012 | 09:43 PM
Conanski's Avatar
Conanski
Putting an LS or locker in when changing gear ratios is actually less work than keeping the stock open diff because you don't have to take the old assembly apart.
Old Sep 16, 2012 | 08:41 PM
bassman94's Avatar
bassman94
thats what ive heard, but do you think the lower gears would be worth it?
Old Sep 16, 2012 | 08:57 PM
H3lzsn1p3r's Avatar
H3lzsn1p3r
for what its worth it easyer to find a posi rearend and put it under as a whole my 94 has a posi from factory
Old Sep 16, 2012 | 08:59 PM
bassman94's Avatar
bassman94
think its cheaper or just easier?
Old Sep 16, 2012 | 09:02 PM
H3lzsn1p3r's Avatar
H3lzsn1p3r
sorry it is cheaper if you can find one not so easy to find
Old Sep 16, 2012 | 09:04 PM
bassman94's Avatar
bassman94
yea, itd be nice if the dude who ordered the truck just got it to begin with... annoying.
Old Sep 16, 2012 | 09:07 PM
H3lzsn1p3r's Avatar
H3lzsn1p3r
i have the 4.9 so it seems pointless to have the low gearing with posi but makes up for the 2wd fact
Old Sep 16, 2012 | 09:09 PM
bassman94's Avatar
bassman94
yea thats true, i got the 351 with 4x4 the thing is a tank. its got all the extras.. cept that.
DieselBeast01
2004 - 2008 F150
Dec 4, 2011 01:47 AM
870
Apr 8, 2007 12:49 PM
455 Jet
1997 - 2003 F150
Jun 20, 2003 01:45 PM
dassmoof
1978 - 1996 Big Bronco
Jan 30, 2003 04:51 PM
Chipster
Nov 16, 2002 09:22 AM
