E4OD
Old Sep 11, 2012 | 01:36 AM
johnbrown's Avatar
johnbrown
E4OD
HUI,I have a 1995 f-450 super duty truck that i have a problem with.
When i start from a dead stop i have the truck act like went into neutral
then it the trany reconnects had it scanned and it said there was a problem with a shift solenoid,but for some can not find enough info.
about it,where it is located,how to replace it.
I have looked on several forums no info. about it at all.
In the few days we going to flush the trany hope that will help a little,thanks
Old Sep 11, 2012 | 07:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The shift solenoids are inside the pan. It is REALLY easy to replace.
Old Sep 12, 2012 | 01:51 PM
johnbrown's Avatar
johnbrown
E4OD
HI,The problem i have with my truck is it feels like it drops out of gear
and if you go thru the gears one at a time then you do not have as much
problems shifting,was told this could be just one solenoid that is wrong in trany,but you can not find out anything about which one is which or
the cost of solenoids it does not help when there is more month then there is money any help would be appreciated,thanks
Old Sep 12, 2012 | 03:30 PM
SOB Racing's Avatar
SOB Racing
Mark is correct about location within the pan. There are a bunch of them down there but very easy to replace. I am sure if you search this site there is a post which details the one your looking for.
Old Sep 12, 2012 | 10:21 PM
powerstroke72's Avatar
powerstroke72
Thread moved to the Clutch, Transmission, Differential, Axle & Transfer Case forum.
JordanTP77
Feb 28, 2019 08:17 AM
Aj Hayes
Apr 6, 2016 05:57 PM
DANA SCOTT
Nov 4, 2005 07:00 AM
putzhall3
Oct 20, 2005 04:49 PM
austin834
Jul 28, 2005 10:50 AM
