Trans cooler
Old Sep 10, 2012 | 05:58 PM
soldier233rd's Avatar
soldier233rd
Trans cooler
Okay I'm back again with maybe another stupid question ( seams like I have a ton of those ). Noticed that my trans cooler is zipped tied to the fins of my radiator, found this when I took the grill insert out to paint them. My question is any ideas on how to properly mount it.
Old Sep 10, 2012 | 06:21 PM
redroad's Avatar
redroad
Where it is will effectively do the job and should have 4 rubber tape squares, Each mounted in a corner to quiet any vibration caused friction that could rub wear the radiator otherwise that is how most after market coolers mount.
Old Sep 10, 2012 | 07:23 PM
grinnergetter's Avatar
grinnergetter
These are just small angle for the brackets and I'm pretty sure it needed a spacer on the upper right hand corner.
Old Sep 10, 2012 | 08:01 PM
soldier233rd
grinnergetter I like that set up thanks for the pic. Looks like two pieces of angle iron. Bolted or welded on, and did you just run bolts thru loops in the cooler to mount to the angle.
Old Sep 10, 2012 | 08:03 PM
fmc400's Avatar
fmc400
MSEE
Does your radiator not have a transmission cooler built in?
Old Sep 10, 2012 | 08:28 PM
soldier233rd
No I believe this it still the stock radiator and the stock trans was a manual. The motor and trans where swapped before I got the truck.
95copperhead
17
Feb 18, 2019 09:48 PM
1985 Bronco
Oct 26, 2018 07:54 PM
F350dog
Feb 8, 2016 04:11 PM
wicat3
Sep 3, 2012 12:51 PM
Heykma
Aerostar
Oct 13, 2004 12:56 AM
