1992 f150
Old Sep 10, 2012 | 03:23 PM
Cowgirl386's Avatar
Cowgirl386
1992 f150
Idles fine but when I push on gas peddle too hard I loose cylinders but in neutral I give gas slow it doesn't skip but if I hit it hard it skips. Help I've replaced fuel filter plugs wires and map sensor
Old Sep 10, 2012 | 04:34 PM
fordbrother0421's Avatar
fordbrother0421
what motor do you have in it?
Old Sep 10, 2012 | 04:41 PM
subford's Avatar
subford
Sounds like a bad TPS (Throttle Position Sensor) that is mounted on the end of the throttle shaft.
But you should see if you have any codes stored in CM (Computer Memory).
To see if you have any codes stored you can go to this link for information on how to do it:
Fuel Injection Technical Library » How To Run a Self-Test
Old Sep 11, 2012 | 07:40 PM
FordYoungGun35's Avatar
FordYoungGun35
If that doesn't work, try replacing the cap and rotor... Same thing happened to my 96 and I did a "6 liter tuneup" and it was fine
Old Sep 11, 2012 | 08:18 PM
Cowgirl386's Avatar
Cowgirl386
I'm trying a tps replacement tomorrow cuz everything I've check is working well
Old Sep 11, 2012 | 09:39 PM
FordYoungGun35
Tps Is a strong possibility but if that doesn't work try what I told ya
Old Sep 11, 2012 | 09:59 PM
Cowgirl386's Avatar
Cowgirl386
I will. I'll let ya know how it turns out thanks for the look out
probmx24
17
Dec 6, 2010 01:02 AM
gearhead351
Sep 13, 2009 02:17 AM
Terrapro
Apr 23, 2009 03:26 PM
peacock
Jun 25, 2007 07:17 PM
matt3763
Jan 17, 2005 06:49 AM
