I am rebuilding a "91 AOD for my truck project.
I have the stamped steel forward clutch drum.
There are 2 snap ring grooves for the return spring.
I need to make sure which groove the snap ring goes into.
The one closest to the end of the hub?
or the one closest to the piston?
I am pretty sure it is the one closest to the end of the hub, but I hope some "AOD GURU" can verify for me!
I took it apart and didn't notice 2 grooves until a few days later....
Hopefully I am on the right track.
And maybe even tell me why there are 2 grooves ???
I cant remember seeing 2 snap ring grooves there, I will grab one tomorrow and look at it.
Care to take a pic of the drum and snap ring grooves?
Thank you for your reply!
I would take a picture, but I assembled it yesterday.
I am gonna be out of town starting tomorrow morning thru next Sunday evening, so I couldn't take a picture til then...
Right now, I have the snap ring in the groove closest to the end of the hub or farthest away from the piston.
I hope this doesnt sound lazy, just bad timing for pics...Work gets in the way sometimes...ugh.
When I get back, I will certainly take a picture.
It wasn't difficult to take apart, and it may help someone else in the future.
I haven't found a single mention of this on the web...
If you do get a chance to look at one, please post your findings. I am not home and it will be in the back of my mind til i know..i am stuck in a hotel room for three days. i feel like someone cut off my hands...cant do anything on my truck this week...ugh!
I couldn't find much for a AOD in the shop today, these things are just about obsolete in my world, but it got me thinking. I dont know of a stamp steel drum for the forward drum for the AOD. The AOD forward drum has a hollow input shaft that allows the direct drum shaft to go through. It is a cast drum and a steel shaft. The only steel drum for the forward is for the AODE and the 4R70W, these drums will not work in a AOD.
The direct drum in the bottom of the case is a cast drum also, but a stamp steel drum from a later AODE and 4R70W will interchange. So I think you might be referring to the direct drum instead of the forward drum.
The direct drum has a snap ring groove for the snap ring and a groove for the lip seal for the piston. I cant see how to confuse the two so a picture will still help out. If you have the snap ring in the groove furthest away from the piston its correct.
A couple pics...
The forward drum, and a pic of the pan with the dipstick plug still in the pan.
What makes the stamped forward drum not work in an AOD?
I understand the obsolete in your world, most of these are not in todays vehicles. got ya.
Of course this is not a pic of the center, but it's all I got being 5 hrs from home.
I agree, the snap ring should be farthest away from the piston.
Again I will take a pic of that center when I get home next Monday.
I can't guarantee that this tranny has never been apart. but this is what it had. according to some, it could have either a cast forward or a stamped, after 1988.
Please don't detour from your experience, just because I have heard this or heard that. I am not in the tranny business. I wish I was, but am not.
I only know enough to be dangerous!
i just realized you are a Master Certified Transmission guy.
Guys like me are probably a major pain in your rear, aren't we..
I am not trying to make a living working on these, just trying to do this project all myself.
One of my problems...I like to know things like "why would a groove be there if it is not needed"
Then the red light goes on, and I start thinking...and researching....and...and...but I am determined to get through this.
Please just tell me if I am bothering you, and I have no issue moving on.
I really would understand...
I don't have friends anymore, because all they ever want is to get free automotive repairs, and when I needed something in return...they are all busy...so believe me...I do appreciate you even taking a minute to help.
Your pictures show the second groove I keep calling a snap ring groove.
I can tell now, it's not...I think those pics are the only ones out on the web that show what I am referring to.
Thanks for clearing this up for me!
In the picture it is clear, there is only one groove for the snap ring.
I see a second groove...not as deep.
When you look at it from an angle in the garage and the light is not perfect, That second groove LOOKS like a second snap ring groove.
Again, looking at his picture, you can clearly tell it's not a snap ring groove.
But there is a groove below it.
So you don't see it?
