Bronco II Ford Bronco II
Need help with 88 B2
Old Sep 9, 2012 | 03:20 PM
maria88's Avatar
maria88
Cool Need help with 88 B2
Ive owned the truck for about a 1 1/2 yrs. Have had nothing but problems with it. Something goes wrong i fix it. Love the truck. But at this point im tempted to get rid of it. Right now im having problems keeping it running. Runs fine in park, neutral, reverse. As soon as i put it in drive and try to go it dies on me. Then it wont start again unless i let it sit for couple hours. Last time i had this problem it was the ignition control module. Well i broke it tryin to get it off to go test it so had to replace it anyway. Wasnt the problem. I also needed a new Idle air control valve. Has needed one for awhile. All that really fixed was the spuratic idle i had. Im kinda lost. I know tranny is fine. Just had it rebuilt. Coil maybe? but why only drive? Any help or advise would be much appreciated! Thanks!
Old Sep 20, 2012 | 02:23 PM
old boxer's Avatar
old boxer
have you tried checking the feul filter, and feul pressure it shoul be around 40psi if filter is backed up could be your problem.. good luck
Old Oct 4, 2012 | 01:40 PM
ned37's Avatar
ned37
what about the torque convertor lockup clutch? it may b stuck in the lock position. one way to test it would be to jack up the rear wheels in 2wd and with a fairly high idle, put it in d.
ExtrmZ
Dec 6, 2009 06:41 PM
NaviShock
Sep 3, 2007 07:24 AM
raceman3
Aug 1, 2007 08:12 AM
87ford
Oct 20, 2006 03:00 PM
junkntrunk
1978 - 1996 Big Bronco
Jan 14, 2005 12:39 AM
