help! stalling/poor idle
Old Oct 1, 2006 | 12:42 AM
87ford's Avatar
87ford
ok ive had this problem for a while now and i dont even know where to start..i wus sitting in traffic today for about 10-15 mins...slow moving..i problly let the clutch out about 2 or 3 times to move up and when the traffic started to move my truck wus bucking and backfiring like if i wus running out of gas or sumthing...so i pulled to the side revved it a few times and it wus fine..but it has done this a dozen times and i have no idea what it could be..?
Old Oct 1, 2006 | 12:56 AM
khadma's Avatar
khadma
Carpenter Local 745
It could be many things, when was the truck tuned up last?
I know it sounds silly, but you have to start diagnosing somewhere, plus your description of your problems are vague. Give us more info so we can help you better.
Old Oct 2, 2006 | 06:14 PM
87ford's Avatar
87ford
the fuel filter is new the plugs are new ..ill buy a new cap wires n rotor n see what that does but ive been trying to fix this problem for a long time and it stops for a month or so and then comes back
Old Oct 2, 2006 | 11:11 PM
87ford's Avatar
87ford
and when i went to leave work today my truck wouldnt idle..so maybe the culprit to all of this is the idle air control valve?
Old Oct 3, 2006 | 04:28 AM
mississauga's Avatar
mississauga
For a start remove the iac and clean the pintle and that general area with carb or throttle body cleaner. If it hasn't been servviced in a while it is usually gummed up. Check the wiring connector to make sure the contacts are clean.
Old Oct 3, 2006 | 08:14 AM
87ford's Avatar
87ford
i replaced the iac today and it still doesnt idle!
Old Oct 3, 2006 | 09:19 AM
low92flareside's Avatar
low92flareside
Sounds a lot like a fuel pressure issue to me. have you checked your fuel pressure at the fuel rail?
Old Oct 3, 2006 | 09:25 AM
MustangGT221's Avatar
MustangGT221
https://www.ford-trucks.com/forums/1...all-users.html
Check computer codes.
Clean IAC on throttle body
Check for vacuum leaks
Also, please don't forget to include vehicle information when posting (or put it in your signature).
Old Oct 3, 2006 | 02:38 PM
87ford's Avatar
87ford
How Do I Make A Signature?
Old Oct 10, 2006 | 12:10 AM
preppypyro's Avatar
preppypyro
Up near the top on the left there is a user cp. Click it, go in there and edit signature, and you can make one up. Might want to check more of the settings in there too, personalize it to your liking!
Old Oct 17, 2006 | 10:10 PM
Murk's Avatar
Murk
Um, is it just me or does anyone else NOT have the sig option there? I've scoured these boards to try and find it, but I dont have it anywhere in my user cp. =(
I just want to include my favorate vehicle in my posts.
Old Oct 17, 2006 | 11:06 PM
preppypyro's Avatar
preppypyro
Ok so when you click into user cp, theres no edit signatures, right at the top of the options? Like on mine its control panel, then settings and options, tehn right under that is edit signature.
Old Oct 17, 2006 | 11:21 PM
Murk's Avatar
Murk
You are magic! It's there now.
Seriously, I'm not a forum newb, I swear to GOD it wasn't there.
Thanks!
Old Oct 20, 2006 | 12:01 AM
preppypyro's Avatar
preppypyro
Anytime man
Old Oct 20, 2006 | 03:00 PM
MustangGT221
Thanks preppypyro for helping him.
One thing I'd like to point out is that not all users signatures appear in the actual post. If you're not an FTE supporter, your signature will appear under your post count in a hyperlink that a user can put their mouse icon on in order to see your signature.
Supporters are able to have their signatures shown in all of their posts.
RubyRed350Platinum
Jan 14, 2017 01:03 PM
CC'sDad
Jul 14, 2016 11:47 AM
southtexasidi
Oct 2, 2015 10:39 AM
polarbear
General Automotive Discussion
24
Mar 21, 2006 07:25 PM
nictic
1983 - 2012 Ranger & B-Series
Jul 11, 2004 10:51 PM
