Trans problems on a 2002
Old Sep 9, 2012 | 09:36 AM
srteach's Avatar
srteach
Looking for ideas on a truck my father recently bought. 2002 F250 7.3L Auto CCSB, 189K miles. Hutch/Harpoon/Pre-pump Filter. Full and clean trans oil, no leaks anywhere (engine or trans).
When starting out (cold), the truck runs like a turtle. The engine RPM runs to 1500, but the ground speed increase is extremely slow. Actually acts like you are creeping.
When starting out (engine warmed / hot), the trans pushes a little better, but essentially the same acceleration.
The truck will eventually get to speed, it just takes a LOOOONG time. My father thinks it is stuck is OD, but the OD off light will not go out.
Is this a controller issue or could this be more involved?
I'm flying blind with the trans here, guys, so any thoughts or tests would help.
Old Sep 9, 2012 | 05:00 PM
srteach's Avatar
srteach
Update: The OD off light blinks until the trans is warmed up. Then the trans behaves normally.
No one has a clue?
Old Sep 9, 2012 | 05:20 PM
timmyboy76's Avatar
timmyboy76
friend had something similar. Removethe steering column shell, and check out the wires run'n from the shifter. See if you see any frey in them.
Old Sep 9, 2012 | 05:45 PM
srteach's Avatar
srteach
Will do that. Thanks.
Old Sep 9, 2012 | 06:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first step is ALWAYS get the codes read. The places that read codes free can't read the codes you'll need, so you need to go to a good independent shop or a Ford dealer.
Old Sep 10, 2012 | 05:58 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Can't he find someone with A/E, it is my understanding it will read all the codes. If it doesn't I'm glad I have not got one yet. (waiting to get a new laptop, last one died)
cstempert
Ford Truck Parts for Sale
Aug 9, 2016 03:31 PM
beanhead6D5
Jul 26, 2012 09:51 PM
gneub25
2004 - 2008 F150
Feb 23, 2010 06:13 AM
