Loud Clunk
Old May 15, 2003 | 02:29 PM
No_BS's Avatar
No_BS
Loud Clunk
Evertime i hit the gas or let off after accelerating there is a fairly loud clunk coming from somewhere in the rear of my truck. I checked the u-joints and there fine. Could it be the ring&pinion or the transmission. I'm hoping it's the tranny becasue it already makes clicking noises evertime it's moving that are easly heard from in the cab. I'm thinking of getting a new tranny, but would a rebuild solve this problem? It's a E4OD.
Old May 15, 2003 | 02:42 PM
billman's Avatar
billman
Loud Clunk
Double check your tranny mounts and engine mounts while you are at it.
I think the typical reply you will get from this is grease up the spline on your slip yoke. Worked for me. Good luck.
Old May 15, 2003 | 07:03 PM
steve83's Avatar
steve83
Loud Clunk
What truck are you working on?
Check the yoke nuts on the axle pinion and the t-case (4WD only) - they sometimes get loose, allowing the shafts to wobble in the bearings.
Old Jun 5, 2003 | 09:48 PM
sweetsugar's Avatar
sweetsugar
Loud Clunk
I was havin the same problem with my 2001 screw after only 35,900 miles. My dealer couldnt seem to find the problem( convieniently). He had the truck 2 differnt times. I took it to my personal mechanic and he said that it was the differntial pin that was worn and cracked, which made it loose so it clunked when I excelerated. Now Ford can pay my mechanic!
ken1960
6.7L Power Stroke Diesel
15
Dec 4, 2013 09:53 PM
EMS-guy
Aug 19, 2011 08:01 PM
Vinford
Feb 4, 2009 05:59 PM
evilhorde
1978 - 1996 Big Bronco
Jul 22, 2005 04:59 PM
teatowej
Apr 28, 2005 09:37 AM
