Water got low, throwed a code
Old Sep 9, 2012 | 04:46 PM
EXv10's Avatar
EXv10
Originally Posted by Monsta
Check the carpeting under the dash. Maybe the heater core is leaking. When do you smell it the most?
The sensor must be in coolant to give an accurate reading. If yours was low it could have exposed the sensor to air, hence it telling the PCM that it is too hot.
After I drive it sometimes and around front of the truck I might catch a whiff. I'm thinking maybe a water pump, or maybe a bad cap because water has come out the cap before but only one time when I towed my snowmobile up to 8,000 ft. on Mt. Shasta.
I think the sensor was exposed to air. I didn't know it would instantly shut the engine down and go into a limp mode where it hardly had any power.
Dano1017
General Diesel Discussion
Feb 24, 2015 03:21 PM
Jimmy Mills
Escape & Escape Hybrid
Apr 22, 2012 10:42 AM
BIG ATS
Modular V10 (6.8l)
Jul 13, 2011 10:56 PM
bvbunky195
Apr 30, 2010 07:32 PM
rad1026
Apr 22, 2010 01:52 PM
