General Diesel Discussion
Code P0088
Old Feb 24, 2015 | 03:21 PM
Dano1017's Avatar
Dano1017
Code P0088
Ok need some help, replaced HPFP 38,000 miles ago. Truck began going in limp mode without engine light, wrench came on in dash, gave codes for brake switch, anti-theft, some other weird codes. Had those codes cleared, ran for while then water separator came on, drained the water out, came back on. Read some forums, so I removed and cleaned the housing, cleaned off the sensor. Had code cleared and ran good for about a week. Then guess what engine light comes on, limp mode. Went to Auto Zone, pulled code P0088. This truck runs awesome until limp mode. No other problems. I take it to the ford dealer, scanner pulled P0088 and the water separator code again. I have read alot of remarks about this P0088 code. Can there be another cause for pulling this code, only 38,000 miles later. I had them do the TSB 12-07-07 but I have also read it can only be done if the P0088 is the only code. Please advise, my bill is up to $4500.00. I just really feel there is an underlying issue with these 6.4's. Thanks for any advise!!! Frustrated!!!
btdrygulch
1983 - 2012 Ranger & B-Series
Mar 26, 2025 09:35 AM
Dano1017
6.4L Power Stroke Diesel
Feb 26, 2015 11:13 AM
5.4L to Freedom
Apr 13, 2010 10:42 AM
F450 Aaron
Aug 8, 2007 04:04 PM
paco1945
13
Mar 4, 2004 08:48 PM
