Fuel Issues
Old Sep 8, 2012 | 02:17 PM
mrlpthomas's Avatar
mrlpthomas
Fuel Issues
I change my fuel filter and fuel water separator filter on 2004 F250 6.0L. Cycled my ignition on and off like I'm suppose too. The truck ran for a few minutes and died. I can only assume there is air in the lines now How do I bleed the air out or is there another issue I'm not aware of. I used Motorcraft filters.
Old Sep 8, 2012 | 02:24 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sounds like you didn't get the filter in correctly...... remove it and re-install.
Old Sep 8, 2012 | 02:50 PM
mrlpthomas's Avatar
mrlpthomas
I removed both filters and made sure they were in correctly. What I did notice there wasn't any fuel in the fuel water separator. I thouht cycling the ignition would bleed the air.
Old Sep 8, 2012 | 06:31 PM
69cj's Avatar
69cj
That is the mot common place for a damaged O ring or filter not installed correctly. It then sucks air. Did you lube the O ring? Use oil or vaseline, not diesel fuel. The diesel can cause the O ring to swell and then distort.
Old Sep 8, 2012 | 06:45 PM
mrlpthomas's Avatar
mrlpthomas
I used grease on the o-ring to make sure it slid in easily. I've also removed it again to verify the filter was installed correctly and checked the o-ring.
Old Sep 9, 2012 | 02:11 PM
mrlpthomas's Avatar
mrlpthomas
I want to thank everyone for the help. Finally resolved the problem, had to bleed all the air thru the top fuel fliter reservoir by turning the key on and off and removing any access fuel from the fuel bowl. It took a little time but worked. Never realized how much air entered the system when changing the filters. I'll know next time.
Old Sep 9, 2012 | 02:37 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I've never had an issue... Except for the fuel dumping everywhere when changing the frame filter.
Josh
Old Sep 9, 2012 | 06:01 PM
69cj's Avatar
69cj
It's not normal to have that problem when the filters/O rings are installed correctly and the kon/koff procedures are followed. I would bet you had a lower filter air leak and inadvertantly corrected it.
Old Sep 9, 2012 | 07:13 PM
BLADE35's Avatar
BLADE35
And make shure to lube them Orings I use Oil
ZackF350Di
Mar 24, 2017 03:36 AM
artfd
Jan 1, 2012 08:13 PM
bhillis
Jun 7, 2007 08:35 PM
emilbanks
Sep 15, 2003 08:20 PM
busdriver1
Jul 3, 2001 12:33 PM
