6.0 heads interchange
Old Sep 8, 2012 | 12:20 PM
f3fidy's Avatar
f3fidy
hello all.
im back to rebuilding my 06 f450 and trying to locate some heads
cuz then shop said mine are cracked.
i already bought a set of oem HGs with arp's and when i compare them to
my 04 HGs, theyre definitely different.
im having trouble trying to find late model 6.0 heads and
am wondering if i can use, say, 04 heads with my bigger dowel
HGs? i know theres a taper dowel out there somewhere, but it just
seems that the gasket seals are gonna be mis-aligned or something...
and if thay are interchangeable, then are all heads and HGs also?
just need the right dowel?
thanks!
Old Sep 9, 2012 | 10:52 PM
f3fidy's Avatar
f3fidy
eh anyone?
Old Sep 9, 2012 | 11:00 PM
bismic's Avatar
bismic
late model heads can fit any engine I believe, but not the other way around (at least that is my understanding)
Old Sep 10, 2012 | 07:02 AM
mustang_309's Avatar
mustang_309
Have you checked tousley ford parts? they have pretty good prices. I believe that the larger dowels started with engine builds of somewhere in january of 06, so if your block has the larger dowels the earlier heads will not work as they have smaller dowel ports.
Old Sep 10, 2012 | 09:53 AM
cheezit's Avatar
cheezit
make sure if you use 04 heads that the rocker box is for 9 hole wave rails and not the 8 hole logs.
Old Sep 11, 2012 | 12:15 AM
f3fidy's Avatar
f3fidy
i know theres a step dowel out there somewhere,
which i guess means heads can interchange..
i hope everything else bolts up tho...
i should be able to use my old rocker box
if it fits the old heads!
thanks fellas!!
Old Sep 11, 2012 | 06:38 AM
mustang_309
The step dowel will work if your block has the 18mm dowels and you are using heads with the 20mm dowel ports. If your block has the 20mm dowels, heads with the 18mm dowel ports wont work.
6.0's rock
May 2, 2016 01:34 PM
j.c.you
Apr 6, 2016 05:09 PM
Shaneb75
Jan 2, 2015 11:20 AM
olfordsnstone
Jul 6, 2013 08:06 PM
f100guy
Sep 8, 2004 04:04 PM
