X codes and B codes are in
Old Jan 14, 2013 | 04:29 PM
  #46
JumpinJoe's Avatar
JumpinJoe
Originally Posted by 7.3Excursion4x4
Does anyone have the V & B Ford part #'s?
What about the spring code #'s on the door?
Thanks
Why not find one or two donor F-250? Worked for me. Used Auto Parts | Used Car Parts | Auto Salvage
Old Jan 14, 2013 | 04:30 PM
  #47
jamesbfishin's Avatar
jamesbfishin
V codes- 2C3Z-5310-HA
B codes- 3C3Z-5560-CA
And in case you wanted this option
X codes- 2C3Z-5310-AF
Dont have the Ford part #'s for the D/G codes
Old Mar 11, 2014 | 09:44 PM
  #48
mjoyce's Avatar
mjoyce
confused.
I want a small lift and for my excursion to ride and handle better. I also want to continue to park it in the garage. The roofline is 76 inches And the opening isn't huge 84 inches.
What is the lift you get from these springs? 3 inches?
Also am I correct in understanding after the spring install the excursion was no longer level as of passenger and driver?
What are the part numbers needed for the swap?
I went to 4wheelparts and they weren't much help. Only offer a 4 inch lift costing a grand or more.
Old Mar 11, 2014 | 10:17 PM
  #49
mjoyce's Avatar
mjoyce
more info
Originally Posted by golfmedik
I am going to order the 4" blocks and u-bolts to level mine out. As you know, mine sits a little low in the rear with a full tank of fuel. Just not the look I like. I used to say that the Hellwig was the best mod I'd ever done to the X. Now I know the spring change is the best I've done. The ride is so much better, not to mention the handling. Of course, the Hellwig still helps. Like many others have said, I wonder how successful the X would've been had it had decent springs, sway bar and a couple of our other 'favorite' mods we've done on here. I know it was killed by Bill Ford with his 'green' ways, but I still can't help but wonder.
What is the hellwig mod you refer to? sway bars? which ones?
What springs did you go with?
Front?
Rear?
Do you tow with it?
I tow a 10k 33ft camper. I want a lift and still be able to park in my garage with a 7ft opening. Wondering if this is the solution that I need.
Old Mar 11, 2014 | 11:01 PM
  #50
wpnaes's Avatar
wpnaes
Originally Posted by mjoyce
I want a small lift and for my excursion to ride and handle better. I also want to continue to park it in the garage. The roofline is 76 inches And the opening isn't huge 84 inches..
With the V/B swap you'll have at least an inch to spare.
What is the lift you get from these springs? 3 inches?.
Depends on how saggy your front ones are. I got 1.75'' with my used V's; others get more. Rear won't change much unless you do the Mod-B or change the rear block.
Also am I correct in understanding after the spring install the excursion was no longer level as of passenger and driver?.
My passenger and drivers side were within 3/8'' of each other.
What are the part numbers needed for the swap?.
All listed in the Tech folder on the top of the Ex Forum.
No surprise, they're not around to help, but to make a profit. That's why you're here on FTE. Spend that grand on a winch bumper.
Old Mar 12, 2014 | 06:59 PM
  #51
WE3ZS's Avatar
WE3ZS
All vehicles vary somewhat, no more or less than pre-spring swap here.
You will get much better advice and help here than they could ever hope to offer!
What is the hellwig mod you refer to? sway bars? which ones? Yes, the rear hellwig sway bar is very popular here, runs about $200 and has a big impact on the EX's handling.
Front? V code fronts from a PSD SuperDuty truck will tighten things up and give less than 2".
Rear? Modded B code rears from a SD truck will do the same.
Do you tow with it? I added modded X/B codes to mine to improve towing performance, 39' 10k TT here. The spring swap transformed the EX into a completely different vehicle, it's a towing dream now!
It's the solution I went with and I couldn't be happier with my results.
I can't add anything to sean's Home Run answers here!
Old Mar 12, 2014 | 07:43 PM
  #52
golfmedik's Avatar
golfmedik
Front?
Rear?
Do you tow with it?
Thank you Tom for answering....been away from the forum most of the last two days. But Yes, what Tom said! I went with V/Bs...long story, but turned out better than I could've imagined.
Monty
Old Apr 13, 2015 | 12:18 AM
  #53
Watcher58's Avatar
Watcher58
2000 Ford Excursion V-Code Leaf Spring Installation pictures, videos, and sounds | SuperMotors.net
This is a good description with pics on the spring exchange
Old Apr 13, 2015 | 01:56 AM
  #54
Stewart_H's Avatar
Stewart_H
I don't like pointing people to that thread because the person who put it together doesn't instruct people to pull the front bumper in order to get access to the front spring eye bolt.
I much rather point people to the tech thread here in the Ex forum, specifically this thread https://www.ford-trucks.com/forums/1...l#post11391676 for step-by-step instruction.
Stewart
Old Apr 13, 2015 | 01:54 PM
  #55
Watcher58's Avatar
Watcher58
Stewart
Thanks I went under and was looking at the front eye bolt holy crap!
ToolmakerRob
Mar 19, 2017 10:35 AM
SNIPER168308
Jan 16, 2016 06:23 AM
73ferdf250highboy
18
Jul 24, 2013 11:05 AM
wbuffetjr1
Mar 28, 2011 09:07 PM
mcjones44us
Apr 29, 2007 10:28 AM
