X codes and B codes are in
Old Sep 13, 2012 | 09:20 AM
Footy's Avatar
Footy
Originally Posted by glebreton
I have an 01 EXC 7.3L 4WD and hope to replace springs in near future. Read a little about them but need more info on the options out there. When I got it, it had lots of sway in turns and bottomed out way to easily. Replaced the shocks first day I got it and not much improvement. Added Timbren Suspension enhancement, but that was basically larger bump stops, so it helps on tows and softens bottom outs, but doesn't do much for unloaded ride. What are the spring options out there and what is best for me? I don't need a cadillac ride, and don't mind a "truck" ride. I do tow at times, a 5000lb boat and a 10000lb camper. Need some beef in the springs to give me stability when towing that heavy camper. Thanks
I just went through this same deal with the exact same model truck. I use V code front springs from a F350 dually. B code rear springs from a F250 SD with a service body. Not all f250's came with these heavier springs so you will want to check the door sticker if you get them from a junk yard. Some guys like the even heavier X code front springs if they are running a big front bumper with a winch. i am very happy with the results so far. Just did this last week.
Old Sep 13, 2012 | 12:03 PM
Stewart_H's Avatar
Stewart_H
Read a little about them but need more info on the options out there.....What are the spring options out there and what is best for me?
In my opinion, we can all chime in and tell you what to get. The problem is, if you do the mod and it's not to your liking, you won't be happy.
Now I know it's a lot of reading, but you really need to do the research yourself (again, just my opinion) so you can see how the different combinations have worked for others and you can make an informed decision on what will work best for you.
So, all that "reading" has been compiled here in a link in this post: https://www.ford-trucks.com/forums/1...l#post11373753
Click the link for the compilation thread in that above post. It's lots of reading, but you'll be able to figure out what you want for your rig.
Stewart
Old Sep 13, 2012 | 03:20 PM
Pitcrw6's Avatar
Pitcrw6
X looks great. These are next on my list for the X.
Old Sep 13, 2012 | 06:26 PM
EXv10's Avatar
EXv10
Do a search in here and read everything that looks like it might apply to your mod. When I had/have my radiator problem I read all I could about it and I am getting closer to resolving the problem. I never just through money and time at something hoping it will turn out right. You might run across one sentence that says " I wish I used the V's instead of the X's because now it's way too high and the wife hates the way it rides" read, read.
Old Sep 13, 2012 | 07:14 PM
jamesbfishin's Avatar
jamesbfishin
Im a newbie to the Excursion world, but from what I have read the V codes up front and modified B codes in rear are the most popular choice for spring replacement, I went with the X codes up front because I dont mind a truck ride and wanted to get about 2 1/2' of lift with just springs. X codes are the heaviest spring available before getting into the F450 and F550 arena, and even with the X codes it is still the smoothest riding diesel truck I've owned not harsh at all. Springs have been in for a week and havent had a chance to load it up with a trailer so not sure how it will do yet, many guys are quite happy with towing ability after spring swaps, wont be towing my boat until probably December for winter haul out so that report will have to wait, boat weighs in at around 7500 lbs. Air bags are always an option for you with the camper if the springs dont seem like enough for your set up.
part #'s I used
X codes 2C3Z-5310-AF
B codes 3C3Z-5560-CA
Like these guys say, read read read....I spent about 2 months reading and re-reading before deciding what I wanted to do
Old Sep 13, 2012 | 07:23 PM
jamesbfishin
Thanks, Im quite happy with it
Youre gonna wonder why you waited so long
Old Sep 13, 2012 | 09:07 PM
EXv10's Avatar
EXv10
I might install them if I towed, but my trailer and cargo total 1,000 pounds. Trailer=400 pounds, Snowmobile=600 pounds
Old Sep 14, 2012 | 10:25 AM
Big Sky's Avatar
Big Sky
I have a question for those who have replaced their springs. Does the vehicle handle better on washboard and rough gravel roads? Right now our Excursion is not a pleasure to drive on washboard roads, about 20-25 mph max. It is really bad, like I'm afraid of the nuts and bolts coming loose. My shocks are failry new, so I don't think that's the issue.
Old Sep 14, 2012 | 10:30 AM
Pitcrw6's Avatar
Pitcrw6
From what I hear its like having a new X right off the lot. Im getting stuff ready to do mine.
Old Sep 14, 2012 | 10:35 AM
golfmedik's Avatar
golfmedik
On washboard roads I don't know as I haven't traveled any. What I can tell you is that on roadways that have been patched repeatedly, there is just a dull thump! Much better than the dash rattling jarring I used to get.
Old Sep 14, 2012 | 12:14 PM
EXv10's Avatar
EXv10
Anything is better than bottoming out.
Old Sep 14, 2012 | 04:09 PM
jamesbfishin
Only had the new springs in for a week and it was commute to work and back, which there was a vast difference in the way she handles, nice and solid with just a small thump absorbed by spring instead of bumpstop going over expansion joints. Heading out on the beach tonight to fish in the surf, so this will be first time off road, cant wait.......
Old Sep 14, 2012 | 06:58 PM
  #28
golfmedik's Avatar
golfmedik
Have fun doing both. Driving and fishing!!!
Old Dec 9, 2012 | 05:32 PM
  #29
jamesbfishin
Update on the spring swap on my EX, after about 5000 miles the EX rides awesome still had a bit of the factory rake to it, unfortunately I dont have the measurements from before and after the initial swap, lost the paperwork with the #'s on it.
Today I used an idea from WE3ZS and modified my X codes as well
The overload spring from the B code that was removed and not used found a new home as the bottom spring in my X codes, drilled holes in the ends of the spring for the plastic discs to help prevent squeaks and swapped them in. Truck sits exactly level, measuring 41" from the ground on all 4 fenders. I gained an additional 7/8" lift using the overload springs up front. Best part, the ride hasnt changed at all, nice firm feel over bumps and in corners but not at all harsh or bone jarring. post some pics when weather clears.
Old Dec 9, 2012 | 06:59 PM
  #30
golfmedik's Avatar
golfmedik
Update on the spring swap on my EX, ............... post some pics when weather clears.
That sounds cool! Pics wanted!!
