E4OD problem
Old Sep 18, 2012 | 12:03 AM
onpier5's Avatar
onpier5
E4od
Originally Posted by onpier5
Installed new solenoid pack harness. This did not help. And yes. I am getting 12volts to the red wire with key on engine off. And with key on engine on. If I check voltage between pin 11 and 12 the voltage jumps all over from 4 to 10 volts. But if I check from pin 12 to a good ground, I get 12 volts.
Originally Posted by ford trans tech
you have no power on the red wires at the solenoid.
when they are off due to no power the trans will always start off in 4th gear in drive and when manually shifting either to manual 2 or low it will always be in 2nd gear
If I'm getting 12 volts to the red wire, what else can I check? And if I'm getting 12volts from epc? What other diagnostics can i do?
Old Sep 18, 2012 | 12:06 AM
onpier5's Avatar
onpier5
I also removed the LED tail/brake lights and installed normal bulbs.
Old Oct 2, 2012 | 11:30 PM
ford trans tech's Avatar
ford trans tech
then i would suspect the processor is not getting power . or it has failed
can it be eec. tested and codes retrieved
Old Oct 3, 2012 | 09:44 AM
onpier5's Avatar
onpier5
Thanks for all of the responses. It ended up being something wrong with the valve bodies. Trans guy replaced and it's working good now.
Zapp911
Oct 11, 2022 03:32 PM
ml8on
1978 - 1996 Big Bronco
15
Apr 23, 2014 11:58 AM
rob rosencrans
Jan 19, 2009 09:52 AM
