carb adjustment help
Old Sep 7, 2012 | 09:56 PM
61 uni's Avatar
61 uni
I have a new to me 83 f150 with a 302. It has the factory carburetor on it. The choke seems to work correctly but it doesn't idle high enough when you first start the engine and wants to stall when its put in gear. How do I adjust the idle when cold? It idles fine when warm.
Old Sep 8, 2012 | 09:01 PM
Franklin2's Avatar
Franklin2
The cam for the fast idle is on the passenger side of the carb. I know the aftermarket Holleys have a adjustable screw that rides on the cam, but I am not sure the factory has the screw. If it doesn't, your only option is to make the choke close a little more, by turning the large black plastic housing on the pass side of the carb in the "richer" direction. This will bring the screw up to a higher bump on the cam.
Old Sep 11, 2012 | 12:11 PM
61 uni's Avatar
61 uni
Does the screw need to be turned in or out to speed up the fast idle?
daveinva
Nov 8, 2018 08:15 AM
61 uni
Dec 26, 2007 09:55 PM
sfc11b
Dec 20, 2005 12:34 AM
lksouth
Apr 10, 2004 11:54 PM
cjben
Apr 15, 2003 10:40 PM
