How do I adjust the fast idle?
Old Dec 26, 2007 | 11:47 AM
61 uni's Avatar
61 uni
83 f150 302. I got the choke working right ( i think) this morning but the fast idle doesn't kick in. It will die when you put it in gear. How do I adjust it?
Old Dec 26, 2007 | 08:32 PM
Franklin2's Avatar
Franklin2
Look at this link, at the very bottom. You will see a "fast idle adjusting screw" This is on the passenger side of the carb. If you look a little farther up the diagram, and a little bit to the right, you will see the "fast idle cam". This is a little half moon piece with steps on it. The fast idle screw rests against these steps when the choke is on.
http://www.autozone.com/images/cds/g...3d800acdf1.gif
Old Dec 26, 2007 | 09:31 PM
61 uni's Avatar
61 uni
You must be the carb guru around here. You allways answer my questions. Do I screw the screw in or back it out the increase idle speed?
Old Dec 26, 2007 | 09:55 PM
Franklin2's Avatar
Franklin2
Screw it clockwise or in. Remember it's not going to have any affect unless the choke is on. When the choke is off(engine fully warmed up), the fast idle cam rotates down out of the way.
Bradenc2015
Sep 9, 2013 06:13 PM
hacking_in2002
16
Dec 10, 2008 10:56 PM
61 uni
Dec 28, 2007 08:44 PM
the kid
Nov 3, 2006 01:05 PM
bluesky636
Aug 8, 2004 04:56 PM
