General Automotive Discussion
2005 Ford 500 no start problem
Old Sep 6, 2012 | 11:06 AM
kentuckyredneck's Avatar
kentuckyredneck
My grandpa's car won't start. We thought the battery was dead, but we tried jumping it with my truck ('92 F-150 group 65 battery with 850cca) and that didn't help. Had the cables on for 10-15min. All we got was what sounded like the solenoid "popping" and the starter might try to turn slightly. Mainly just the popping/clicking sound though. We even hooked my battery straight to the battery leads and it did the same thing. Any thoughts?
Old Sep 6, 2012 | 11:39 AM
tjc transport's Avatar
tjc transport
i ain't rite
dirty battery connections.
or a shorted out battery.
Old Sep 6, 2012 | 11:47 AM
kentuckyredneck
The battery is probably bad. We've had to add water once or twice. The connections are clean. Only thing is, even when basically swapping my battery in, it doesn't help.
Old Sep 6, 2012 | 12:00 PM
tjc transport
i ain't rite
with a bad battery, the only way to get it running is to completely remove that battery from the circuit. it will draw enough juice to keep it from starting or running.
try swapping a known good battery into the car and see what happens.
Old Sep 6, 2012 | 02:37 PM
kentuckyredneck
We unhooked the cables & ran the jumpers straight to the leads, not the battery.
Old Sep 6, 2012 | 02:43 PM
tjc transport
i ain't rite
that really don't do much unless you have large welding cable and 300 amp ends on the jumpers. most jumper cables will not supply the amount of current needed to start an engine. they usually work because the in car battery is not completely dead, and you sit for a while charging the low battery from the jump car before trying to start.
and even with thick cables i have seen no starts, but drop a good battery in and hook up the cables it starts rite up.
GreatNorthWoods
Escape & Escape Hybrid
Apr 15, 2018 06:36 AM
granny_rocket
Feb 21, 2016 12:29 PM
TpaBayFlyFisher
21
Mar 7, 2015 06:47 PM
Excursion123
Apr 1, 2013 11:52 PM
RyanMiller
Electrical Systems/Wiring
Oct 16, 2004 05:09 PM
