Battery
Old Apr 1, 2013 | 12:24 PM
Excursion123's Avatar
Excursion123
Smile Battery
Hi I have a 2000 ford excursion with the 7.3. It has 2 large batteries in it. If I ever needed to jump start somebody's car witch battery should I use?
Old Apr 1, 2013 | 12:27 PM
Stewart_H's Avatar
Stewart_H
Either one, it doesn't matter.
When it comes to replacing one though, make sure you always replace both, even if one tests good.
Stewart
Old Apr 1, 2013 | 05:13 PM
Patriotic Rottweiler's Avatar
ditto, just what he said...
You can jump start from either battery, because they are wired together.
Also replace both at the same time. if you only replace one, then the remaining battery will quickly kill the new battery.
Old Apr 1, 2013 | 06:43 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
And as a side note, when you need to jump yours (if you ever do) I think the pass. side battery goes to the starter,,,
Old Apr 1, 2013 | 06:53 PM
Excursion123
Ok thanks guys. Do both batteries crank the starter or does one power the electronics and the other is for the starter?
Old Apr 1, 2013 | 11:52 PM
Stewart_H's Avatar
Stewart_H
Diesel engines are high compression engines and need both batteries to power the starter to turn the engine over.
Stewart
kentuckyredneck
General Automotive Discussion
Sep 6, 2012 02:43 PM
traffic142
Jun 13, 2012 08:46 AM
Tony_C
Dec 13, 2011 11:53 AM
kneisl99
22
Oct 30, 2011 12:07 PM
RyanMiller
Electrical Systems/Wiring
Oct 16, 2004 05:09 PM
