Sponsored by: Kumho
Anti-Lock Breaks delete
Old Sep 6, 2012 | 10:54 AM
hollenjoe's Avatar
hollenjoe
Im wanting to delete my abs brake system in my f150 2002 2wd all disc brakes.
I have to change the module with some kinda valve? and turn off the Abs in a tune?
I know the basics of a brake system, but im lost in the abs stuff, any help or parts i need,
thanx
Old Sep 7, 2012 | 07:47 AM
fmtrvt's Avatar
fmtrvt
Pull the fuse.
Old Sep 7, 2012 | 10:47 PM
4x41977's Avatar
4x41977
Why do you want to get rid of the abs?
Old Sep 13, 2012 | 06:48 PM
Muffinman's Avatar
Muffinman
You can't just pull the fuse, You have to find the ABS control module and disconnect it there. Most are under the dash and a big square box. Doing that makes the brakes default to normal function, You don't need some weird *** kit to do that.
Old Sep 13, 2012 | 06:52 PM
hollenjoe's Avatar
hollenjoe
thanx, I will look for it.
Old Sep 13, 2012 | 07:26 PM
fmtrvt's Avatar
fmtrvt
Our test drivers would pull the ABS fuses all the time to disable the ABS as part of NHTSA FMVSS 105 and 135 vehicle tests for stopping distance. In many vehicles you have to find the correct one of the two fuses.
And for the next question, we had almost a dozen F-150s in our test fleet.
Old Sep 13, 2012 | 07:34 PM
Muffinman's Avatar
Muffinman
And for the next question, we had almost a dozen Superdutys in our test fleet.
That fuse runs other stuff, You can't just pull it without loosing power to lights, radio, etc.. what ever is also being feed off that circuit. Just pull the connector at the ABS box and the light goes out.
rsav
Feb 1, 2020 12:39 PM
irydasteelhorse
Jan 3, 2018 06:01 PM
beeser
Oct 11, 2013 10:07 AM
Hiflyer746
May 10, 2006 07:08 PM
SoCalDesertRider
Electrical Systems/Wiring
Mar 6, 2004 01:38 AM
