thermostats
Old Sep 5, 2012 | 08:31 PM
oldgrayman's Avatar
oldgrayman
thermostats
Sorry to ask noob questions, but, when I dismantled the 59-AB motor on my '46 pickup, there were no thermostats in the cooling system. Now that I'm ordering parts to finish rebuilding it, I'm a little confused. I assume the thermostats rest against the water intake on the heads, but, what holds them in place? Is it just the friction from the upper rubber radiator hose? Also, Dennis Carpenter lists thermostats as 160 and 180 degree - which should I use if the truck will only be driven during the warmer months?
Old Sep 6, 2012 | 06:35 AM
petey shoes's Avatar
petey shoes
the hose will hold them ok. just be sure they don't get twisted when installing hoses. i use 170's on mine, got them from napa. you don't want it to run too cold.
Old Sep 6, 2012 | 07:25 AM
oldgrayman's Avatar
oldgrayman
Thanks, Petey! Just what I need to know.
Old Sep 9, 2012 | 12:18 PM
5 Star's Avatar
5 Star
For what its worth to you I was speaking with a man in Nevada, who owns a 37 Flathead he runs 180 thermostats in his and he told me he runs the desert in high heat and it works great.
You just have to have a good clean cooling system, all the necessary components like fan shroud, belly pan this all contributes to the cooling system working as it should.
If you can't get good thermostats which is quite common these days with the china junk. Fender washers with 5/8 inch hole will work just fine.
Greg Rogers
May 24, 2018 05:58 AM
palmrose2
Oct 10, 2017 09:39 AM
texasJ
2004 - 2008 F150
Sep 10, 2014 05:36 PM
KR1
13
Jun 25, 2009 01:59 PM
Joe fix it
Dec 29, 2004 10:26 PM
