So my 1986 f250 with a 1995 powerstroke engine and dash and wiring in it is giving me a couple problems. Everything was working good till randomly my brake lights quit along with my hazards, and everytime I try to use either of them the abs light starts flashing 15 short and 1 long. Ive checked all the fuses, checked the brake switch, and all the bulbs. Signal and marker lights work. cruise works but does not cancel with the brake pedal. Its the same problem described in this thread; https://www.ford-trucks.com/forums/1...d-for-now.html
yes I checked all the fuses and they are all good. and I replaced the original cargo light with the high mount stop light. I had a trailer hooked up with the flat 4 pin connector when it happened.
