Sponsored by: Kumho
RABS light flashing
Old Sep 1, 2008 | 04:28 PM
shotgun's Avatar
shotgun
RABS light flashing
Working on my 1996 F150 4x4. While driving around, up pops the first problem with my truck. The RABS light started flashing. I also noticed that the brake lights quit working. I pulled the code from the ABS module and it comes up 16. (SYSTEM working normal). When the light flashes when driving around it flashes a 16 as well. The Haynes manual seems to indicate that when you have abs trouble the ABS light should illuminate and stay lit and not flash? Is this correct? I checked all the basic fuses and the brake light switch. The red parking brake light seems to be working normal.
Any ideas if the ABS light and non functioning brake lights are related????
Thanks,
Chris
Old Sep 1, 2008 | 06:14 PM
projectSHO89's Avatar
projectSHO89
Sounds like your ABS test plug is still grounded.
Steve
Old Sep 1, 2008 | 07:37 PM
shotgun's Avatar
shotgun
I forgot to mention that the hazards lights do not work either. I have checked all fuses. Found the hidden flasher for the hazards and confirmed that it is working. I have removed the hazard/turn signal switch to check that out.
Old Sep 2, 2008 | 12:09 PM
Lazy K's Avatar
Lazy K
Steve
Could well br right. No brake lights will cause problems with the RABS. Get those fixed and go from there.
