2011 F250 Fx4 diesel. I'm pulling a 14' GN dump trailer. My truck squats and I would like advice on which way to go. Should I go to ford and get a quote to put the overload package on or put in an airbag system? If it helps, I want to put a on-board air compressor in for air chuck use and louder horn. Any suggestions on systems?
Hey Jsgilliam, an air bag system would work out well in your application. In fact, we offer a 57396 kit for your 2011 F250 4WD. You can learn more about the system here: LoadLifter 5000; Leaf Spring Leveling Kit.
Let me know if you have any questions regarding these products, I'd be more than happy to assist you.
Originally Posted by biz4two
^^^ ditto ^^^
I have the camper package with the overloads...and they are nice, but need a lot of squat to start doing the job they were intended for.
My '12 F250 sits level empty...so when I add my 7x20 cargo trailer that has a GVWR at 7000lbs...the truck squats some...and not enough to engage the overloads.
So...I'd recommend going with the airbag setup. In case you haven't seen it...here is a video done by a FTE member. Which I really do like this setup...
While I have to agree with you on the Tigas - I have to disagree with you on the RAS...
I have a set in my garage I pulled off my 2012 since roadmaster would not honor the 30 day money back guarantee....
nothing burns me up more than a company that does not honor it's advertising !
And also note that while the airbags will level it out,
it will do NOTHING as far as adding to your legal GVWR or GAWR ....
if your overweight, you'll still be overweight
jdadamsjr is right. Make sure you are not overloading your truck or exceeding your vehicle's weight ratings. Doing so is dangerous and would void the Air Lift warranty.
