Educate me on air bag suspensions - Ford Truck Enthusiasts Forums
Old 01-21-2018, 01:53 PM
Pilgrim6 Pilgrim6 is offline
Pilgrim6 is starting off with a positive reputation.
for my 1994 F250 Super Cab 4WD Diesel.
I would like to improve the ride when running empty, as well as be able to lower the ride height a few inches. Do Air Bags REPLACE the stock leaf springs, or add to them? Do I remove a couple of leafs for soften the ride and then use the air bags to regain the weight capacity when I need it?
I do not think I want to do anything to the rear--but again, I am open to being educated.
I tow a 7000# camper a few times a year, and run empty most of the rest of the time. My wife has knee and back issues, so lowering the cab a few inches might make it better for her to get in and get out--sort of like the "kneeling Buses" I see around town. I see on the hot rod shows that they can pretty much put a car on the ground--but what about a truck?
Old 01-21-2018, 02:46 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
If you watch a complete show where they build something to ride on the ground like that you will see that they have to chop and channel the frame and sometimes also modify the body to allow the axles to travel further up into the vehicle.
Without doing that riding on the stock bump stops is as low as it will go, and yes to get the full range of movement the factory springs are completely replaced with airbags.
Old 01-21-2018, 03:37 PM
mrollings53's Avatar
mrollings53 mrollings53 is offline
mrollings53 is gaining momentum as a positive member of FTE.
The kits you find from Firestone, or Air Lift go on top of the factory spring, and are meant to level a load, not increase payload capacity.
Kneeling buses have a complete airbag suspension. Doing that to the front axle on a 2WD truck, or coil sprung axle isn't hard, because the spring doesn't locate the axle. Just replace the coil spring with an appropriately rated airbag, and brackets.
Leaf sprung axles are a different story, because the springs locate the axle. Something would have to be fabricated to locate the axle fore, and aft before airbags could be added. This wouldn't be to hard for the rear axle; people do 4 link suspensions all the time. I've seen pictures of people converting the TTB axle to coil springs. After that you would need to convert to airbags.
And, then after all of that is done you may still need to modify the frame to get the height you want. Honestly, a set of steps is what you need, and maybe a grab handle on the A-pillar.
Old 01-21-2018, 03:47 PM
Robert Long's Avatar
Robert Long Robert Long is offline
Robert Long is starting off with a positive reputation.
Steps and a set of quality air ride seats for the Misses.
Old 01-21-2018, 08:35 PM
Anyone have plans for a powered step that swigs out when the door opens? Could be electric or vacuum powered. It should swing up by the frame when not in use so it is not an obstruction to get torn off by some road hazard. I am open to suggestions.
Old 01-21-2018, 09:17 PM
Junk yard parts from escalade and a little fabrication.
Old 01-22-2018, 05:16 AM
Thanks.
I didn't know that Escalade's had that feature.
I will go looking.
Old 01-22-2018, 06:03 AM
A lot of newer vehicles have automatic steps. Companies make steps for older trucks too, but I couldn't find anything for an OBS truck. You may be able to make something work given enough time, and money.
Old 01-22-2018, 11:08 AM
Scndsin's Avatar
Scndsin Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Quote:
There is a Jaguar XJ6 converted to 4X4 that shows up at Cruising The Coast each year.
It has about foot square diamond plate boxes that run the length of the rockers.
When the guy hits the button, 2 sets of (lengthwise) steps roll down & lock in what I can only guess is some sort of electro/mechanical or hydraulic fashion.
They stop about a foot off the ground.
Ugly as hell car, but when he drops the steps, it's pretty cool, cause they are fast & when they lock down or up you hear it.
Very "transformer" like, but damn functional. (fun to watch too)
Don't think I've ever gotten good pictures.
Old 01-22-2018, 12:36 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
I have seen AMP steps modified to work on am OBS. But I will be damed if I would spend $1000+ on steps and still need of modify them to work
Old 01-22-2018, 04:01 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud of
Didn't Lincoln Navigator have fold out steps? Open door and they drop down? Again, have to find junkyard to maybe make it a cheap enough project.
Old 01-22-2018, 04:11 PM
Yeah, do something like this:
Installed a Sulastic on a 450 42pilot 6.7L Power Stroke Diesel 4 01-19-2018 11:14 AM
anyone remove a leaf in a 250 with air bags? kcducttaper 1999 to 2016 Super Duty 2 04-21-2017 02:40 PM
Improving empty ride quality Bassboatman 1999 to 2016 Super Duty 51 11-21-2016 02:51 PM
Safety Issue (Air Bags) Photos attached. bkuuz1 6.7L Power Stroke Diesel 44 10-10-2016 12:50 PM
Bounce with new rite right air bags Bigpipes 35 Fifth Wheel & Gooseneck RV Towing 22 10-03-2016 10:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
