Lug nut stud thread size question??
Old Sep 4, 2012 | 08:55 PM
abriel68's Avatar
abriel68
Hello everyone, soo i have a 1991 f350 i just bought me some 3" wheel spacers for my truck, also some 8x6.5 rims for it too. When i went to install the wheels i noticed that the threads from studs where a different size then the studs on the wheel spacers. Also the Lug nuts on the original studs wont fit down the shute on my wheel spacers. So my question is, what size threads are on my hubs? and im hoping i can find smaller lug nuts to bolt my wheel spacers on. Thanks for the help fte.
Old Sep 4, 2012 | 10:29 PM
nvrsatisfied84's Avatar
nvrsatisfied84
the truck studs are 9/16-18 the spacers are prolly 14mm the new nuts should say on the side
Old Sep 4, 2012 | 10:39 PM
abriel68's Avatar
abriel68
when i bought the wheel spacers they were 8x6.5 to 8x6.5. bolt patterns, and the lug size was 9/16 to 9/16 . I'll check both lug nuts to see if they say the size on the side. The new lug nuts seem a little too small, the thread pattern looks close to the same.
Old Sep 4, 2012 | 10:42 PM
White 97 xlt's Avatar
White 97 xlt
If you absolutely NEED spacers, you need to get ones that fit correctly before you kill yourself or someone else!!!!
It would be MUCH safer to buy the correct wheels in the first place... Looks are not everything!!!!!!!
Old Sep 4, 2012 | 10:49 PM
abriel68's Avatar
abriel68
the wheels bolt pattern and the wheel spacers are the same bolt pattern, my issue is just with the lug nut thread difference between the two. Thats why im here trying to clearify everything so everything is installed correctly.
Old Sep 4, 2012 | 11:04 PM
Onus's Avatar
Onus
9/16-18 stock. That year should have 1 1/16th lug nuts. Latter models went to 3/4 lugs.
Doesn't matter what you use as long as you have the right seat type too match your wheels.
3/4 is a bit easier to work with thats for sure.
Old Sep 5, 2012 | 12:11 AM
abriel68's Avatar
abriel68
that sounds right cuz the lug nuts are huge! but what are the thread size? is it a metric or a standard thread if that makes sense?
Old Sep 5, 2012 | 01:18 PM
Onus's Avatar
Onus
Standard 9/16-18. If it was metric it would be like 10mm. There is a possibility your wheel adapters are metric threaded. Why did you get wheel adapters?
Old Sep 6, 2012 | 01:47 PM
southern_gentleman85's Avatar
Good Luck!
Good luck man! Once I bought mine, I found out that I had two different types of lug studs on mine, and the guy before had split some lug nuts forcing them on. He had mixed Shank and cone nuts. It has Mag wheels so I couldn't see the split until the Shank nuts were off. Two full sets of lug studs and nuts later I got the wheels back on.
bignewf
Apr 21, 2016 05:24 PM
tomwerm
19
Apr 27, 2015 02:14 PM
cws10190
18
Sep 25, 2012 08:55 PM
DIYMechanic
Jul 13, 2011 06:04 AM
smclaren
Aug 28, 2001 08:35 PM
