Wheel bolt pattern on all F250 and F350 configurations (SRW & DRW) is 8 on 170mm, hub centric mount. Hub centric mount means the hole in the center of the rim is precisely machined to fit over the raised portion of the axle shaft. The lug nuts only function is to hold the wheel on. I'm not sure what size the nuts are as my rims (Mickey Thompsons by ALCOA) use the same mounting system and lug nuts.
