Startig Problem
Old Sep 4, 2012 | 04:57 PM
Dajudge51's Avatar
Dajudge51
Startig Problem
Hoping for a little help on this strarting problem.
I have a 69 F100 Ranger that is causing my problems. The engine is a 93
302 ci that runs great. It is a little difficult to start but not bad.
The carb has been rebuilt, new plugs and wires, timing set, carb adj.so it runs with no hesitation, and is electronic ignition. Replaced the battery with stronger than needed and replaced the ignition module. Since it is a 93 engine it is equipted with an electric fuel pump.
I will start it and drive 20 miles till all is at operating temp and wait till i get home before I dare shut it down. I then try to start it and no way. Just turns over. A few days ago someone checked and told me I was not getting fire so was advised to get the module. Tried it today and no help. I didnt check for spark.
Can u get a vapor lock with electric fuel pump ?
Can a coil get warm then breakdown?
It starts and runs great after 30-45 min.
Any suggestions would be helpful.
Thanks,
dajudge51
Old Sep 4, 2012 | 05:28 PM
f5fordgirl's Avatar
f5fordgirl
Yes coils can go bad when they get hot, but you need to check that you have the right coil on it.
Old Sep 4, 2012 | 06:22 PM
Dajudge51's Avatar
Dajudge51
Thanks for the fast reply. I am confused about "the right coil" Thought it was 6 or 12 volt ? I will try a coil tomorrow anyway. Thanks again
dajudge51
Old Sep 5, 2012 | 04:48 PM
Customcab's Avatar
Customcab
Crazy Larry;
Tommorrow let's test the coil and if no problem there; I would believe its the pick-up module in the Dizzy. See ya tommorrow.
289 sprint
1966 - 1977 Early Broncos
Mar 27, 2015 01:53 PM
dakotarider
Mar 28, 2013 09:46 AM
Pappys53
Aug 26, 2012 03:55 PM
"Top Fuel" Bender
Dec 18, 2011 09:40 PM
jdsdidit
Sep 9, 2007 09:30 PM
