Sensor issue or ?
Old Sep 4, 2012 | 02:04 PM
John8061's Avatar
John8061
Sensor issue or ?
Hello: I have a 2001 F250 7.3 170k miles and no issues last six years. Have been towing 6k lb boat. After running about 15 minutes, transmission goes into "limp" mode and takes about 2k rpm to get going, max about 15 mph. Runs and shifts as expected until "limp" mode. No warning lights or indicators on dash. Searching resulted in finding the culprit may be the VSS/ABS rear sensor, particularly as I have been dunking it in water launching boat. If you have other other thoughts, I would appreciate knowing them! Thank you for your help.
Old Sep 4, 2012 | 02:13 PM
CSIPSD's Avatar
CSIPSD
Easiest way would be to remove the sensor and clean it. Any issues with the speedo acting up?
Old Sep 4, 2012 | 02:33 PM
John8061's Avatar
John8061
Thank you for the reply CSI. During the first 15 min or so, there are no issues and when the "transmission "lims" I have been more focused on the tach. I did not notice any speedometer issues but wasn't looking. Is VSS to fail only at normal op temps?
Old Sep 4, 2012 | 02:51 PM
CSIPSD's Avatar
CSIPSD
It can fail at anytime and be just problematic. You can pull it and clean it, might work...
Old Sep 4, 2012 | 04:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You need to get the codes read. It would be very unusual for that to happen without setting one or more codes. The places that read codes free can't read the codes you need. A good independent shop or a Ford dealer are what you need.
Old Sep 4, 2012 | 04:26 PM
1fixitman's Avatar
1fixitman
John. Where are you located at? There may be someone here that could help you reading codes with AutoEnginuity. You could invest in your truck and purchase AE and put it on a laptop and it could help you find the issue.
Old Sep 6, 2012 | 07:54 AM
John8061's Avatar
John8061
Thank you for the replies. Ford scan found no codes. Transmission slipping. BTS here we come...
Old Sep 6, 2012 | 08:09 AM
fordpride's Avatar
fordpride
If the OD light is flashing then you have codes
Old Sep 6, 2012 | 10:15 AM
1fixitman's Avatar
1fixitman
Still no reply to where he might be located.
Old Sep 6, 2012 | 11:11 AM
John8061's Avatar
John8061
Thank you Fordpride, I updated the location as well. The OD light wasn't flashing nor were any other (eg CEL) dashboard indicators. Should there have been codes with a slipping transmission?
ken_wied
1983 - 2012 Ranger & B-Series
24
Sep 16, 2017 02:45 PM
bokker
3.8 & 4.2L V6
Oct 29, 2008 09:11 AM
RC46
Sep 23, 2003 09:29 PM
cwmerc88
Feb 25, 2002 06:03 PM
