Oily EGR?
Old Sep 3, 2012 | 10:40 PM
FordMan35's Avatar
FordMan35
Oily EGR?
My EGR valve has always looked this bad whenever I pull the thing. The bottom looks' mostly dry, and the top is always oily looking. I assume this is because of the oil from the CCV?
I haven't had any coolant loss since I have owned the truck. With the current work I am doing the EGR cooler was dry in the back. Truck parked nose up.
Old Sep 3, 2012 | 10:45 PM
m-chan68's Avatar
m-chan68
How often are you cleaning your EGR valve? When it's sooted up that badly and moist like that, it usually indicates poor combustion as a result of poor fuel quality used.
Old Sep 3, 2012 | 11:11 PM
BLADE35's Avatar
BLADE35
And just think your intake manafold looks the same and so do all the sensors within the intake manafold
Lots of benifit from an EGR Deleate
also try to run Cetan Booster
and check your thermostat you maybe running Cold
Old Sep 4, 2012 | 02:17 AM
Fordflanigan's Avatar
Fordflanigan
Ive heard that the gummynes could also indicate a bad FICM. Might be worth it to check the voltage on your FICM.
Old Sep 4, 2012 | 08:21 AM
FordMan35's Avatar
FordMan35
So what about the rest of the exhaust system? Would it look gummy as well?
I use Stanadyne Performance formula at every fill up. My ECT runs around 195-210 and EOT runs around 198-214. It takes about 20min of driving at 55-65 to get there as well. My FICM runs at 47+ volts when cranking and is 49+ while driving. AE won't read any higher. So unless there is anything else wrong with the FICM I don't think that's it. I get my fuel form the same place 99% of the time. I thinks they have pretty decent turnover, I see people filling up there Trucks ,and Volkswagen's all the time. This EGR valve also went in brand new 2 years ago. Someday a stealth EGR delete will happen. I live in emissions territory so it has to be done right.
Old Sep 4, 2012 | 09:05 AM
bismic's Avatar
bismic
Do you idle a lot? How is your fuel pressure?
Maybe your leaking dummy plug could have affected injector perfromance.
Old Sep 4, 2012 | 11:50 AM
FordMan35's Avatar
FordMan35
I do not idle any more than I have to. Whenever possible I have the high idle turned on. I will be checking the fuel pressure once I get it back together.
Old Sep 4, 2012 | 12:08 PM
bismic's Avatar
bismic
My first EGR valve inspection showed the same thing. It no longer is that way - just dry powder.
The only thing I can think of that I have done differently than what you say you have done already is the ccv mod.
Old Sep 4, 2012 | 03:28 PM
FordMan35's Avatar
FordMan35
The ccv mod is something I have wanted to do for a while now. Bismic do you have the part number for the ccv housing that is on the valve cover? I have a different approach to the ccv mod that will involve modifying that piece.
Old Sep 4, 2012 | 04:20 PM
bismic's Avatar
bismic
I believe these are the part #'s
ccv elbow kit (03 I believe) 3C3Z-6A603-AA
ccv elbow kit (late 04 and up) 4C2Z-6A603-AA
ccv elbow: o-ring ONLY W302725
mikeysfun
Mar 13, 2016 07:53 AM
redbigbertha
Jun 18, 2014 10:33 AM
Volvo92906
Oct 31, 2009 08:42 PM
FORDSDOWNER
Aug 17, 2009 07:11 PM
w_huisman
Mar 20, 2008 07:40 AM
