HELP!!
Old Sep 3, 2012 | 09:25 PM
460 FORD MAN's Avatar
460 FORD MAN
HELP!!
I HAVE A HUGE F-IN PROBLEM!!!!!!!!!!!!!!!!!!!!!!
I JACKED IT UP, TOOK TIRES OFF, SET JACKSTANDS RIGHT BEHIND RADIUS ARMS AS I WAS ADVISED TO DO, AND NOW MY TRUCK IS TEETER TOTTERING ON THE JACKSTANDS!!! THE REAR TIRES ARE OFF THE GROUND ABOUT A FOOT!!!!!!
WTF DO I DO??? I DON'T WANT MY TRUCK TO FALL!!!
<!-- / message -->
Old Sep 3, 2012 | 09:31 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Well, I hope you're kidding, but if not, this is what I'd do.
1-DO NOT GET UNDER IT!
2-If you are on level ground, which I assume you are otherwise the truck would have fallen off the stands by now, have someone push straight down on the rear bumper while you roll a floor jack under the front axle. Jack it up till you can position the jackstands under the front axle.
Old Sep 3, 2012 | 09:33 PM
smokenchoken's Avatar
smokenchoken
throw some weight in the back of it and get something like a steel car rim under the frame repeat do not get under it
Old Sep 3, 2012 | 09:37 PM
CampSpringsJohn
Could probably open the tailgate and set a concrete block or 2 under it. It must be pretty well balanced if you were able to get the tires off and the jack out from under it.
Old Sep 3, 2012 | 09:49 PM
460 FORD MAN
No I'm not kidding! And thanks for the advice so far!!!
Old Sep 3, 2012 | 09:52 PM
CampSpringsJohn
Didn't think so. Hope it works out for you.
Old Sep 3, 2012 | 10:03 PM
460 FORD MAN
Ok, I put my jack under the radius arm, jacked it up, and got the rear tires on the ground. Imma call one of my buddys and see if I can borrow his floor jack and jack both sides up at once and move the jackstands foward. I guess the 460 is heavy enough to lift the whole back of the truck off the ground. Thanks for the help guys!
I know the stuation sounds stupid, I just can't think when I'm stressed like that.
Old Sep 3, 2012 | 10:05 PM
smokenchoken
it happens to the best of us don't let it eat you up
Old Sep 3, 2012 | 10:18 PM
kobaltblue's Avatar
kobaltblue
Use your engine hoist and grab it around the front bumper and core support
He has no bed so its nose heavy.
Old Sep 3, 2012 | 10:27 PM
CampSpringsJohn
That makes sense.
As smokenchoken said, it happens to all of us from time to time! Glad you got it taken care of.
Old Sep 3, 2012 | 10:48 PM
7636074460's Avatar
7636074460
Yeah! 460s are def. Heavy since my 460 truck looks like low rider next to my FE truck lol not to mention our trucks are pretty front heavy to begin with , without a bed mine weighs 4000 lbs and two guys can pick the rear off the ground
rtcapo
Oct 24, 2017 03:27 PM
Rob89
Jul 17, 2017 08:43 PM
StumpPullerF1
Jan 18, 2011 04:13 PM
carrfamilynj
May 23, 2007 07:19 AM
crashandburn420
Nov 9, 2004 10:38 AM
