302EFI problem
Old Sep 2, 2012 | 06:41 PM
Snorri_B's Avatar
Snorri_B
302EFI problem
Hi i have a 1990 Ford Econoline 150 with the 302EFI engine. The engine resently started to have problems starting! it will start upp when the engine is cold but not rigth away and usualy there is dark smoke from the exhaust but when its warmed up it wont start up "not all the time" the starter just turns the motor!! I been told it might be a problem with the wires on the starter and some sugested the timing gear!!!! anyone got an idea ??
Old Sep 3, 2012 | 07:33 AM
Conanski's Avatar
Conanski
Pull the codes and check fuel pressure.. the system should build and hold no less than 39-40psi within a 2-3 cycles of the key, if it never gets that high but holds you could have a weak pump, and if it builds but bleeds off immediately you could have stuck-open injectors or a bad check valve in the fuel delivery module. Also check that there is no fuel in the vacuum line going to the fuel pressure regulator, if there is the regulator is toast and must be replaced.
Old Sep 4, 2012 | 11:47 AM
Cobra-Kai's Avatar
Cobra-Kai
You tell about dark smoke.
Is it more black or blue?
Black means: Runs to rich.
It's either too less air (check the filter!) or too much Gasoline
I know the symptoms you describe more like an BMW-Problem.
When they get older (~20 Years) the Injectors become leaky and start dripping after.
If you got blue smoke: Congratulations - you engine is burning oil
Maybe a minor problem like valveshaft seals
or a big problem like piston rings
Old Sep 4, 2012 | 06:44 PM
Snorri_B's Avatar
Snorri_B
It's more like black smoke when starting up .... i can hear the fuel pump when i turn on the ignition .... could i be having problems with the fuel injectors i replaced the motor a year ago bought it used from and was told it had few miles on it but i think this motor had been siting for some time before i bought it ...
Old Sep 4, 2012 | 08:26 PM
timbersteel's Avatar
timbersteel
What plugs, and what gap are they set at? As Conanski stated, check for codes, either with a code reader or the paperclip method. Could be as simple as he said about the fuel pump being weak, and it does happen. Also, if the diaphram for the FPR is ruptured, it's gonna suck fuel in through the vacuum line and give near about the same results.
Old Sep 5, 2012 | 07:11 AM
Snorri_B's Avatar
Snorri_B
Okey i will tjeck the codes as just have to get a code reader .... i think we were using autolite plugs this time .... usualy use motorcraft but what gap should be on this plugs ? .045 or more ?
Old Sep 8, 2012 | 03:42 PM
timbersteel
Should be around 0.50, and just use a standard motorcraft plugs. No need for fancy platinum, etc.
You can use a paperclip method and it's listed in either a Haynes or Chilton manual. Also, check this site for more info.
Fuel Injection Technical Library
1979BEAST
Nov 19, 2010 04:40 PM
Royson12
Sep 17, 2009 07:59 AM
Ringer97
May 4, 2008 06:01 PM
Primered86XLT
16
Aug 25, 2005 03:00 PM
Vinford
16
Apr 5, 2005 10:28 PM
