Cold idle issue
Old May 19, 2008 | 10:04 AM
fordguy55's Avatar
fordguy55
Cold idle issue
Could use some help since I don't have a diagnostic reader, I'm open to suggestion on a cold idle problem. My 1993 3.0 Ranger idle will go up and down on a cold start, almost to a stall, for maybe a minute or two before settling down. I can keep it steady with the accellerator until it warms up a bit. There are no other symptoms. The throttle plate is free. It runs like a champ with 180k on it. Causes for this?
Old May 19, 2008 | 09:24 PM
whitebassbenny's Avatar
whitebassbenny
haha i know what you are going through. I replace my fuel filter on mine and it seemed to stop it.
Old May 19, 2008 | 09:28 PM
whitebassbenny
https://www.ford-trucks.com/forums/6...n-started.html here u go to my post i made.
Old May 19, 2008 | 11:23 PM
whitebassbenny
hmm it seems that i cant edit the next day(?)
owell you could also try to clean the MAF sensor to or maybe even a new air filter ?
Good luck.
Old May 20, 2008 | 09:51 AM
fordguy55's Avatar
fordguy55
Thanks for jogging the brain cells. The last Plug and wire change was 90k miles ago. Think it's time to replace all of the consumables. If the trouble persists I can go to Advance Auto to pull codes.
