Batteries
Old Sep 2, 2012 | 02:04 AM
Yahiko's Avatar
Yahiko
Batteries
I am not in need yet. Just doing some looking into.
Has anyone used the NorthStar Battery? (Made in the USA)
4 year full replacement
Batteries Plus has them under there own brand name
Group 65 AGM Marine X2Power Battery SLI65AGMDPM - Batteries Plus
NorthStar Group Size 65 AGM Battery - Remy Battery
VS.
Optima YellowTop (Made in Mexico)
http://www.amazon.com/s/ref=nb_sb_no...+YellowTop+D34
Sean
Old Sep 2, 2012 | 05:53 AM
wulfman's Avatar
wulfman
I went to there web site and sounds like they are the sh-t . And the OP's i hear they are not all that anymore .
Old Sep 2, 2012 | 09:25 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
...and you do NOT want a Marine battery in a truck.....
Old Sep 2, 2012 | 09:58 AM
Nice Work Truck's Avatar
Nice Work Truck
I have the Sears Diehard Platinum's and they are GREAT !
Same specks as those.
You might want to look at them.
Old Sep 2, 2012 | 10:56 AM
Sark's Avatar
Sark
Thumbs up
I'll second that!!!
Old Sep 2, 2012 | 11:04 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You don't want a deep cycle marine battery... do you?
Josh
Old Sep 2, 2012 | 11:07 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Not unless you plan on adding a prop to the rear bumper......
Old Sep 2, 2012 | 11:18 AM
Bullitt390's Avatar
Bullitt390
I'm a big fan of Walmart MAXX batteries myself.
Josh
Old Sep 2, 2012 | 03:06 PM
Yahiko's Avatar
Yahiko
OK so why do you not want adeep cycle marine battery?
Group size 65.
Item number: SLI65AGMDPM
Weight: 58.0000 lbs
Voltage: 12V
Capacity: 74AH
CCA: 930
Primary Applications: Marine, Boat, RV, Deep Cycle, Dual Purpose Applications
Replaces: NSBG650002
Sean
Old Sep 2, 2012 | 03:12 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The constant RECHARGING will shorten the life of the battery and prob will NOT be warrantied!
Deep Cycle batteries are meant to be drained to approx. 1/2 and THEN recharged and not constantly hooked to the the alternator like a regular auto battery. Think using it on a boat where it is used for a trolling motor or an RV powering the RV over a weekend THEN charging.
Old Sep 2, 2012 | 03:15 PM
Bullitt390's Avatar
Bullitt390
I would verify that the CCA listed is actual cold cranking amps and not MCA... Marine cranking amps which is just normal cranking amps in a starting battery.
If you're running accessories with the engine off a marine or deep cycle is fine, but they do not usually have to "oomph" needed to crank over engines in the dead of winter like a starting battery.
Josh
Old Sep 2, 2012 | 06:39 PM
Piolet's Avatar
Piolet
Originally Posted by Sark
I'll second that!!!
+3. Diehard Platinums.
Old Sep 2, 2012 | 06:40 PM
mustang_309's Avatar
mustang_309
I've always liked interstate megatron batteries for my gassers, anyone like them for the diesels?
Old Sep 2, 2012 | 07:46 PM
Yahiko's Avatar
Yahiko
Here is the direct link to Northstar
Northstar Batteries - AGM Northstar battery products for all uses.
When I asked for a set for a 6.0L diesel at Batteries Plus
this is the one they recommended over the Optima YellowTop. They sell both.
I was told that the engineers from Optima left and started
there own line and this is there answer to the Yellow Top.
I know that this was a salesman talking even if he is a
car battery specialist. So Tuesday I will give them a call and
get some info from the horses mouth.
Maybe the Optima guy will chime in on this.
Both options are $$$$ and then add a new DC Power alternator
https://www.dcpowerinc.com/ to the mix and we are talking
some big $$$
In the past I have had good luck with Ford and Sears batteries.
I just keep them clean. filled and charged. They will treat you well.
Sean
Old Sep 2, 2012 | 07:53 PM
Bullitt390's Avatar
Bullitt390
Still unsure why you're stuck on the Marine battery. The standard battery is far superior with more cold cranking amps, more reserve, more capacity.
Northstar Battery PL-AGM 65
Josh
